Author Topic: Help & advice for buying new coil  (Read 1732 times)
kev126
  • Built not bought
« on: April 15, 2013, 04:44:39 PM »
Hey everyone, I'm after a new coil for my BIS but they seem so expensive. I've found a few in the £50 region but I don't know if they'll work. I don't want to shed out money for something I can't return!
I am hoping that a fellow member can confirm if any of these are the right ones. Many thanks,
Kev :)
http://bit.ly/17BApkB
http://bit.ly/10XBfmC
http://bit.ly/10XBluH
1989 Fiat 126 BIS
jokke
Re: Help & advice for buying new coil
« Reply #1 on: April 15, 2013, 05:01:02 PM »
they are correct.. :)
1980 Mazda RX626
1985 Mazda RX7
1998 Fiat 126p V6
« Reply #2 on: April 15, 2013, 06:22:18 PM »
 This one is slightly cheaper, but you have to calculate in postage cost. It would probably be worth it if you also ordered some other bits.
 http://www.126fan.sk/eshop/index.php?main_page=product_info&cPath=3&products_id=558
 Why do you need a new coil?
kev126
  • Built not bought
« Reply #3 on: April 15, 2013, 06:27:22 PM »
Thanks guys :) the 126.fan and Axel Gerstal coils work out at £50 posted so I may as wel just go with the eBay one then it will arrive quicker.
I have a running problem which it's now believed to be the coil. And if it isn't... It'll be nice to have a new one anyway!
1989 Fiat 126 BIS
fixit
« Reply #4 on: April 15, 2013, 07:29:24 PM »
do you have a sparker?
rather cool device that goes in between sparkplug and ht lead when there is spark traveling down wire it lights up, if it lights up coil is working with engine cranking and running
http://www.amazon.co.uk/Laser-2780-Ignition-Spark-Tester/dp/B003AN1VPW/ref=sr_1_2?ie=UTF8&qid=1366049939&sr=8-2&keywords=spark+plug+tester
check for 12v at the coil the wires may have broken somewhere and the movement of the engine is keeping it going, youll have to do a wiggle test while running:P
(meaning wiggle the wires)
your 126 will be new
hope this helps
f
« Reply #5 on: April 15, 2013, 08:23:00 PM »
I reckon the Seicento coil pack might work, But who's going to be the test pilot :yikes they can be picked up on ebay really cheap what do you think? :-
Seabee1978126
« Reply #6 on: April 16, 2013, 08:55:37 AM »
I've heard of many people having their coils overheating. I would look at those cooling fins before buying. I just installed one in my 126. I changed it from the orignal points system. Another 200 euro down on the kit for my hobby...
kev126
  • Built not bought
« Reply #7 on: April 16, 2013, 10:11:31 AM »
I will try and find time to remove it later for inspection :)
Pete - if I had the money or access to a scrapped one I'd try it in a flash :D
I've ordered a pair of sparkers to see what's going on, my coil might be fine and would save me a bucket! Thanks for all your help guys :)
1989 Fiat 126 BIS
