Author Topic: What did you do to your 126 today ???  (Read 168360 times)
JonW126
« on: April 13, 2013, 06:17:46 PM »
Today, I waxed and polished the 126 and changed the petrol filter as I noticed it was showing signs of debris in the filter on the underneath ...... Shockingly mucky once I got it off ..... Yuk !
« Last Edit: July 08, 2014, 11:52:00 PM by Pete126 »
grubscrew
Re: What did you do to your 126 today ???
« Reply #1 on: April 13, 2013, 06:28:46 PM »
 Did you fill up at the Esso garage in Heathfield, as thats what mine looked like when I did. :P . Mike
All things Italian.
Hazey-n-Marc
  • It's Hazey's car, she does let me fix it sometimes
« Reply #2 on: April 13, 2013, 07:08:25 PM »
Get a spare fuel filter, the tanks rust inside but still look fine outside. A new tank isn't much more than the fluid to coat the inside of the tank with. And you have to remove the tank to seal it anyway.
Marc
Kent126
  • Closer every day to getting on the road....
    • Facebook Profile
« Reply #3 on: April 13, 2013, 07:25:41 PM »
New tank and lines all the way!  ;D
Tom
1974 Italian Fiat 126 TA
1996 Fiat Cinquecento Sporting
2008 Fiat Panda 100HP
JonW126
« Reply #4 on: April 13, 2013, 07:31:34 PM »
Tom
That sounds like a job for a garage ???
wsmitwil
« Reply #5 on: April 13, 2013, 08:39:42 PM »
Tom
Easy job
I do all the jobs on my car even the paint job
If you don't do the job you don't know your car
fiats forever
JonW126
« Reply #6 on: April 13, 2013, 09:06:58 PM »
Easy job
[/quote]
To access the tank do I just need to just put the rear on ramps ???
Is there a step by step guide on here anywhere b any chance ????
wsmitwil
« Reply #7 on: April 13, 2013, 09:21:58 PM »
Pretty strait forward make sure there is no fuel in it, on to the ramps
Take the two hoses of the pump
And two more hose clips, one on the filler and one on the breather
Three nuts to hold the tank on
fiats forever
popik81
« Reply #8 on: April 13, 2013, 09:23:12 PM »
new spark plugs in:) but still somethink wrong....:(
« Reply #9 on: April 13, 2013, 09:44:15 PM »
Drove it like every other day to within an inch of it's life....
JonW126
« Reply #10 on: April 13, 2013, 09:50:16 PM »
Anyone have a full list of the parts that are needed for this job and a suggestion where to get them all ?
Assume it'll be new tank, new tank neck rubber and new hoses... how many metres ???
Hazey-n-Marc
« Reply #11 on: April 13, 2013, 11:02:58 PM »
I got my tank through axle gerstl, just fuel line (6mm I think), tank and sender gasket should be all you need. Check 126 fan and axle gerstl to see which is cheapest.
The hardest bit was reattaching the filler and breather pipes, found out after that you get better access through the interior side panel.
Marc
JonW126
« Reply #12 on: April 13, 2013, 11:36:05 PM »
Marc
Sender Gasket ??? :headscratch: what's that ?
Blonde126
« Reply #13 on: April 14, 2013, 12:56:53 AM »
Drove mine today - as it is my main (and only!) car :P
But recently blown up the tyres, checked the brake fluid, put on a dust cap that had been nicked, and inspected my bodywork. Tomorrow I'm driving back to Uni which is a 70 mile trip, so will top up the water. Can't wait for a relaxing Sunday drive, the weather forecast looks good!
