Author Topic: What did you do to your 126 today ???  (Read 168547 times)
Xylaquin
« Reply #330 on: August 12, 2016, 07:57:00 PM »
Replaced the door cards, looking a bit more presentable now. Although now I'm not sure what colour of fabric to re-do the seats with, since they matched the beige/white/grey original cards. I don't want dark seats, as that'll make the car feel even smaller.
cider
« Reply #331 on: August 13, 2016, 10:15:20 PM »
Lost my passenger rear light lens  :( >:(blast them crappy plastic headed screws >:(
Club1n
    • Hit me up on Facebook!
« Reply #332 on: August 14, 2016, 09:37:42 PM »
Ran out of petrol at a closed petrol station.. Got rescued by my brother! Found out my petrol gauge has decided to break, going to dig further into it later in the week :p
                                     1978 Works Fiat 126 Rep.
Frigorius
« Reply #333 on: August 18, 2016, 02:48:57 PM »
Installed a new starter, but it seems to block sometimes. I think I have to mail the manufacturer.
Frigorius
« Reply #334 on: August 21, 2016, 07:54:51 PM »
Hi there,
the starter seems to be OK now, didn't hesitate today when I fired her up a few times during the day.
I lubricated the accelerator today, because it sometimes sticks, which is, off course, not a good situation. I also took a look at my front lights, leading to the well known frustration of the little plastic things they have used on the BIS.
While I was doing that, and here comes the question, I also tested the windscreen washer pump and the read window washer pump. They both work fine, I can see the water getting pumped up, but at the rear window, I do not see any water. Can anyone point out where the water should come out and land on the rear window, cause I don't see it :-). It's a BIS from 1989. A picture would be great
« Reply #335 on: August 21, 2016, 08:13:24 PM »
If your standing at the back of the car looking at the tail gate it should be at the top left of the window :thumbup
Frigorius
« Reply #336 on: August 21, 2016, 09:00:25 PM »
That thing in the red square on the picture? That's a kind of "plug" than, I presume. I guessed it should come through there, but is't flat. Maybe they closed it when they threw the wiper away (for an unknown, probably stupid reason). I'm still looking for one, but they are not easy to find. Read wiper motor works.
Marco126
« Reply #337 on: September 21, 2016, 12:11:15 PM »
I had a busy morning doing a steering rack conversion, disc brake conversion, fitting a new reverse eye spring and 14" rims.
Now time for a cuppa, or is it too early for a beer?
Joe Webb
« Reply #338 on: September 21, 2016, 02:34:07 PM »
Oh cool! Where did you get the rack adapter mount thing marco?
Marco126
« Reply #339 on: September 21, 2016, 03:19:12 PM »
I measured it up, did the drawings and had the plates laser cut.
Joe Webb
« Reply #340 on: September 21, 2016, 03:34:12 PM »
Oh fair enough! Will you be making the drawings available? :)
Is there any bump steer?
Marco126
« Reply #341 on: September 21, 2016, 05:50:08 PM »
I see no reason not to make the drawings available.
I still need to adjust my camber when the new spring settles and have it tracked properly. I only did a few miles in it today and I didn't feel any bump steer.
The rack is mounted as close as possible to the BIS mounting position as I could make out from photos I found online, although I don't have the actual measurements from a BIS
Joe Webb
« Reply #342 on: September 21, 2016, 07:08:18 PM »
That's pretty awesome, I'd love to convert mine over some day
Very impressive!
« Reply #343 on: October 10, 2016, 08:04:50 PM »
 I`ve fitted this beauty toady. A virtually new Dell`orto FZD. Big thanks to Rusty`s Uncle again for hooking me up :thumbup
 It runs lovely, just have to play with the mixture a bit.
andyzeetec
  • 126 BIS
« Reply #344 on: October 11, 2016, 01:10:11 PM »
Wow, it's nearly as big as the engine  :good:
