Author Topic: What did you do to your 126 today ???  (Read 168548 times)
cider
« Reply #315 on: July 04, 2016, 11:54:36 AM »
Had to replace the rear wheel bearings ::) so now one less droning noise to worry about  :)
dadandlad
« Reply #316 on: July 04, 2016, 06:10:14 PM »
Swore at it
dadandlad
« Reply #317 on: July 06, 2016, 12:01:40 AM »
I spent a couple of hours cleaning old gaskets off my cylinder head and making new ones from some good quality  gasket material
Bar Vitelli
« Reply #318 on: July 10, 2016, 03:48:41 PM »
Turned the unusual and unique light switch in my Brown on and off...  ;D
Every cloud has one...
mintex
« Reply #319 on: July 12, 2016, 10:46:03 PM »
Taxed it so i'm back on the road  :yahoo:
Not before i had to free my sticking brakes with it standing for a few months first  though :$
Dave
Da Londo
    • Fiat 126 blog
« Reply #320 on: July 13, 2016, 11:14:41 AM »
I started dismantling the engine.
Frigorius
« Reply #321 on: July 13, 2016, 06:36:09 PM »
I got the starter out last sunday and I'm now trying to fix it, or at least I'm trying to find out what the problem is. I will probably have to buy a new one
andyzeetec
  • 126 BIS
« Reply #322 on: July 13, 2016, 08:35:30 PM »
This may help..
http://club126uk.co.uk/forum/index.php?topic=9794.msg73221#msg73221
derekscoopers
« Reply #323 on: July 13, 2016, 11:09:03 PM »
Finished fitting the disk brakes and tidying up the column after converting to RHD, fitted new shocks. also getting the motor connected, at least a bit more done, sparky booked to extend wiring loom early next week.
Yoshimisumi
« Reply #324 on: July 14, 2016, 09:44:01 AM »
Just collected after passing the MOT, then proceeded to breakdown on the way to work...
Da Londo
    • Fiat 126 blog
« Reply #325 on: July 14, 2016, 03:51:38 PM »
I've been sanding the oil filter cover with 150 grain today.
IMG_20160714_161449
wojtix
« Reply #326 on: July 14, 2016, 07:59:35 PM »
new aluminium sump Abarth
« Reply #327 on: August 03, 2016, 12:38:17 PM »
Well not a 126 but my GAMINE with 126 engine, gearbox and other subtle upgrades. Rolled it out of the garage just over, not been run since last year, a week ago to check over for MOT. She started up easily and all electrics worked without some fetteling, first time ever. Put her back in the garage, just had a hip replacement therefore not able to drive. Angela said she would drive it to the MOT station on Monday so got the wee beastie out on Sunday for a final check, paranoid or what, good job as the near side dip would not work. I was getting about 9-10 volts at the bulb connection but when we switched the lights on the voltage disappeared. So major voltage drop on this supply, too many wires to trace location of corrosion, probable cause. I spliced into the circuit for the off side dip as a temporary fix, we don't generally drive at night. She passed with flying colours with only one advisory, an oil leak from the sump gasket. Only another 2-3 weeks before I am allowed to drive again just in time for the forcast good weather.
amam
« Reply #328 on: August 03, 2016, 02:39:44 PM »
bought some alloys  :D
« Reply #329 on: August 06, 2016, 10:31:50 AM »
 I took the engine out again. After the Uxbridge show it started to make a rattling noise from the fan. Doing over 60mp/h with three adults in the car probably didn`t help. It doesn`t look like much, but that fan was making hell of a noise.
 While the engine is out, I`ll be doing some upgrades. Modified head fitted already and a bis gearbox going in soon to keep the revs down a bit  ;D
