Author Topic: wheel fitment chart  (Read 5889 times)
wheel fitment chart
« on: March 23, 2013, 08:29:23 PM »
I am planning to put a wheel fitment chart together, any info on offset and centre hole size would be great, also, what year did they change to 4x98, and what was the pcd before?
marc
eben80
    • AircooledVWSA
Re: Re: wheel fitment chart
« Reply #1 on: March 23, 2013, 09:04:09 PM »
4 x 190
« Reply #2 on: March 24, 2013, 11:12:16 AM »
Cheers Eben.
Right, I know 4x100 will fit with wobble bolts, but will 4x95.25 or 4x101.6?
I also need to know the biggest wheel possible without modifications (width, height and offset), the height will be limited by tyre sizes.
Found this!! http://www.automobile-catalog.com/tire/1988/717935/fiat_126_bis.html
« Last Edit: March 24, 2013, 11:59:09 AM by Hazey-n-Marc »
eben80
    • AircooledVWSA
« Reply #3 on: March 24, 2013, 12:43:27 PM »
I'm sure Pete or someone else would know that. I'm still contemplating a move away from 4x190 at the moment :)
JonW126
« Reply #4 on: March 25, 2013, 09:49:01 PM »
Using the link.... Am I to assume I couldn't fit a set of Mini Classic 175 50 13's to the 126 ??
gason
« Reply #5 on: March 25, 2013, 11:06:20 PM »
That is one purchase I dont want to get wrong buying the wrong tyres or wheels  ;D
JonW126
« Reply #6 on: March 25, 2013, 11:43:52 PM »
I know ..... Where is the help when you need it !?!
kev126
  • Built not bought
« Reply #7 on: March 25, 2013, 11:48:47 PM »
As long as you know the width (J) and offset (ET) and tyre size of the wheels you want to check, visit www.willtheyfit.com
HOWEVER you'll need to know your cars current wheel width and offset
Standard wheels for Fiat 126 BIS
4J (four inches wide)
ET +31
PCD 4x98
Hope this helps
« Last Edit: March 25, 2013, 11:55:17 PM by kev126 »
1989 Fiat 126 BIS
gason
« Reply #8 on: March 26, 2013, 12:32:26 AM »
Cheers Kev until they are on the car I wont be happy
« Reply #9 on: March 26, 2013, 09:12:18 AM »
I am putting something together to help with wheel fitment, the above link gives you tyre fitment, but obviousl;y you have to have wheels on it first that actually fit.
JonW126
« Reply #10 on: March 26, 2013, 06:45:22 PM »
ET +31
PCD 4x98
Hope this helps
Good man ..... Cheers for sharing your knowledge.
« Reply #11 on: April 03, 2013, 12:33:28 PM »
What is the biggest wheel anyone has fitted without modification? Need the offset, width, and diameter. would also be great to know the full tyre sizes as well.
Actually, any non standard wheel and tyre sizes ( J, ET, Inch) and full tyre size would be great, as well as spacer, wobble bolt info and what car they were meant for. The more info I get the better my chart will be, and the less "will this wheel fit?" threads should be needed.
Marc
« Last Edit: April 03, 2013, 12:39:30 PM by Hazey-n-Marc »
