Author Topic: Best place to mount oilpressure/temp. sensor?...  (Read 3217 times)
Topolino
« on: March 13, 2013, 08:23:38 PM »
What is the best place to mount a oilpressure- and/or oiltemp. sensor? Straight on sump? And where if mounted a alloy sump?
And how do I connect it with the instrumentpanel?
kev126
  • Built not bought
Re: Best place to mount oilpressure/temp. sensor?...
« Reply #1 on: March 13, 2013, 09:13:57 PM »
I think only abarth parts have the sensor places, unless you drill your own? You'll probably need seperate gauges to the instrument panel
1989 Fiat 126 BIS
Topolino
« Reply #2 on: March 13, 2013, 10:30:06 PM »
A while ago I bought a 3,5 ltr. alloy sump. It looks like that there is a possiblity to mount a sensor on her side. But that is only one sensor. And I believe this will be meant for the oiltemp. So where will I mount the oilpressure sensor?
In other words, where does Abarth mount her sensors?
On the shelf lays a FIAT 127/850 cockpit with km.-, rpm.-, dynometer and oiltemp./pressure indicators. I like to fix that on the 126.
The alloy sump with on right corner (out of view) the place to mount a sensor?
« Last Edit: March 14, 2013, 12:10:25 AM by Topolino »
« Reply #3 on: March 13, 2013, 11:41:21 PM »
Hi, the existing oil pressure switch can be changed for an adapter to allow the oil switch and pressure gauge sensor. This is the most common way to add a pressure gauge.
Topolino
« Reply #4 on: March 14, 2013, 12:11:26 AM »
Hi Ralph. Do you have any picture of such adaptor?
DEYAN IYI
Topolino
« Reply #7 on: March 15, 2013, 03:01:14 PM »
@ Deyan: Bloody H***! These are expensive. Can't I use a sensor for like say a Cinquecento or some other modern car?
@ Ralph: Better price for this part. So here you can bold the sensor on?
« Reply #8 on: March 15, 2013, 07:05:59 PM »
Hi, yes you screw the adapter into the pressure switch hole and then screw in the switch to the end of the adapter and the sender into the side hole or the other way round if it suits.
Đizel
« Reply #9 on: March 23, 2013, 08:53:18 PM »
this is how i made
Topolino
« Reply #10 on: April 03, 2013, 02:57:18 AM »
Good picture indeed. Now I now where to look for. Did you pay a similar amount as on the Nanni site? Hopefully you did not.
