Author Topic: Building a Sleeper - SPEED on the cheap - what do i Need? :)  (Read 2409 times)
Bolek
« on: March 09, 2013, 12:10:16 AM »
Basically I want a stock looking 126 air cooled that goes like hell!!     what do you guys recommend I do for
-engine
-brakes
-suspension
I want to do it on the cheap, and I want a reliable daily driver, but I also want massively increased performance (albeit keeping air cooled Fiat engine)
so what do i need?  turbo...   abarth engine?   i'm open as long as its easy and affordable!
popik81
Re: Building a Sleeper - SPEED on the cheap - what do i Need? :)
« Reply #1 on: March 09, 2013, 01:46:57 AM »
are You from kraków?? check
http://www.rezerwa126p.pl/forum/index.php?sid=53e3b6d7ffeaee9242b9f5499f6052e2
lots of thinks....
but:
head skim 2mm
365 świątek carb
light fly wheel (4-4,5kg)
carburetr polish, lift up and different nozzle(114)
light time chain set...
if forgot some think.... finis it ;)
« Reply #2 on: March 09, 2013, 09:15:06 AM »
Fast aircooled on the cheap  :o  Buy a cheap BMW or range rover and a trailer  :D
« Reply #3 on: March 09, 2013, 09:42:28 AM »
Bolek, simple why buy a 126 if you want a fast car?
Plenty of cheap fast cars about.
In Poland you will buy a 126 for 500-1000 pln then spend 5000 trying to make it faster.
If you really want a fast 126 just buy an ex KJS car?
DEYAN IYI
« Reply #4 on: March 09, 2013, 12:36:38 PM »
How cheap and how fast!? ;D
With real carb, real air filter, real exhaust, real spark plugs and real ignition (nanoplex) you can gain up to 3-4hp and better dynamic. But this is only a wake-up tuning or soft tuning. Those things you will have to make whatever you build, so this will be a good base for something harder. :P
You can combine standard 263* camshaft with 650E cylinder head. Adjust with 5* the cam, machining the big wheel (so called in polish "prefazowanie"). Fit a BIS's inlet valve 34mm. This way you will have almost a Panda 30 setup. You will have 30hp about 5000-5500rpm for sure. With standard parts only. If you want, you can fit even 35mm inlet valve from CC700.
 :P
Topolino
« Reply #5 on: March 11, 2013, 04:54:04 PM »
Mount a rocket engine  :P
In The Netherlands we call a 'sleeper' a 'Wolf in sheepskin'. I like this way of building a nice car. But don't we all do that? I never seen a racer on the street which already looked like 'Hey I'm fast like a race car'.
« Last Edit: March 11, 2013, 08:44:52 PM by Topolino »
