Author Topic: Double De Clutching  (Read 1688 times)
Blonde126
Double De Clutching
« on: March 08, 2013, 05:35:50 PM »
Obviously 1st gear isn't syncromeshed so I double declutch to get into 1st gear when needed. However, sometimes it doesn't work.
From what I understand, you press the clutch and go into neutral, release the clutch and 'blip' the throttle before then engaging into 1st gear.
Sometimes it works, sometimes there's a little bit of grind (not much!). My question is, how much should you 'blip' the throttle?
Also I'd like to say heel and toeing is very fun :P
grubscrew
Re: Double De Clutching
« Reply #1 on: March 08, 2013, 06:19:06 PM »
I recon to only engage 1st when stationary, but doing it your way probably means the engine revs dont match the speed of the car/gearbox....crunch :cry:
All things Italian.
« Reply #2 on: March 08, 2013, 06:19:32 PM »
Rule 1 - Never, never try and engage 1st gear when the car is moving or you will ruin the 1st & reverse gear set up.
grubscrew
« Reply #3 on: March 08, 2013, 06:23:00 PM »
 Quite.
All things Italian.
Lloyd74
« Reply #4 on: March 08, 2013, 06:26:59 PM »
Wether to use double declutch or not does depend on the type of gearbox the fact that it works sometimes and not others is purely down to the fact that sometimes the gear teeth are aligned when you make the change, and not so much to do with the flair with which you execute this move. The handbook states that 1st and reverse should only be selected when the vehicle is stationary this is for good reason as the design of the gearbox dictates this necessity. Also from a practical perspective you can come to a halt in 2nd and then select 1st to move away having come to a stop 1st or if you havent quite stopped it will pull away in 2nd (perhaps slip the clutch a bit).
Those grindy nudges into gear will lead to £190 ish new 1st gear £15 oil £15 sundries (gasket paste etc) and possibly other costs incurred removing overhauling and refitting the gearbox.
Also it can be a pig to do if you dont have the space time tools or knowhow.
Ive just read this back and it seems like im ticking you off, sorry!
Now be nice to that gearbox or its the naughty step for you!
Hope this helps LLLLLLoyd ;D ;D :P
Im only a Spring Onion but your not gonna stop me rockin!
Blonde126
« Reply #5 on: March 08, 2013, 06:59:17 PM »
Ah ok then guys, I'll have to do that then, don't want to hurt my Bert!
I just thought it was what you had to do when you had no syncromesh on a gear
Thanks guys!
Kent126
    • Facebook Profile
« Reply #6 on: March 09, 2013, 12:47:56 PM »
Yeah what Rusty said! Never use first gear unless stationary!
Which means it is interesting if you need to change down when slowing at lights and you are still slightly moving. It pisses the driver off behind when you stop to change, just to pull away again!  ;D
Tom
1974 Italian Fiat 126 TA
2008 Fiat Panda 100HP
« Reply #7 on: March 09, 2013, 01:10:22 PM »
If slightly moving, I tend to use second gear. I try to let the car run on second on its own accord, rather that using the clutch to help it move.
