Author Topic: Spring is on its way  (Read 2437 times)
Draigflag
  • Got a New Abarth 500 too!
« on: March 05, 2013, 07:48:18 AM »
And it's nearly time to bring the little 126 out of winter storage! There's still a lot of salt on the roads, mainly because it hasnt rained for 3 weeks, but its so sunny, the temptation is killing me! Just need a new fan belt and some tax, cant wait!
Oh by the way, might check the tyres as shes been sitting for a few months. Ive got larger wheels/tyres 155/65 13" I think, what pressure would you put in those?
Re: Spring is on its way
« Reply #1 on: March 05, 2013, 09:03:28 AM »
Should be the same pressure, psi = pounds per square inch so tyre size makes no difference.
Marc
Draigflag
« Reply #2 on: March 05, 2013, 10:14:26 AM »
Ok. What is it?
« Reply #3 on: March 07, 2013, 04:12:53 PM »
I can never remember the correct tire pressure when I decide to check the tires. I tend to use 30 for all tires. It is a little bit on the hard side, but then, the car goes faster!!!
gason
« Reply #4 on: March 07, 2013, 04:54:08 PM »
I wonder is there a life span on tires ? Are the tyres and wheels easily available does anyone know
fixit
« Reply #5 on: March 07, 2013, 10:07:55 PM »
tyres life span is around 5 - 7 years for a caravan if your cars been sitting i think best to follow that advises otherwise
 just check you have more than 1.6 mm tread and tyres not cracked, bulged ,wires showing, or crazed on outer wall. also make sure you have the same size tyre on each axle and they are inflated to similar pressure
there is a date stamp on some tyre walls normally week and year
hope this helps ;D
fixit
gason
« Reply #6 on: March 07, 2013, 11:17:48 PM »
Thats a bit worrying , my cars still on the original tyres and they are nearly 30 years old  ;D
« Reply #7 on: March 08, 2013, 08:33:26 AM »
 :o :o :oChange them then, mine had original fit Stomils on, had one delaminate quite badly, almost bounced the front of the car off the road.
gason
« Reply #8 on: March 08, 2013, 01:51:44 PM »
it has  passed the mot and they are perfect and still got the original spare that has never been used
fixit
« Reply #9 on: March 08, 2013, 02:11:19 PM »
im not sure if age of tyre is in the mot manuel, just the other items i mentioned earlier i was checking for something else and came across.
you can search for the mot class 4 manuel on line to make sure, but bear in mind the police have different criteria than the mot test
 tyre changing is up to the driver and his or her underwear versus pot hole!!
if your collecting card points at a certain supermarket they are connected to a tyre site and you get points, the choice of home delivery, or fitting at a garage they use, for an additional charge.
i used them.
regards fixit
gason
« Reply #10 on: March 08, 2013, 04:06:28 PM »
I will ask my mate who has similar age tyres on his austin healy  ;D
« Reply #11 on: March 08, 2013, 07:18:57 PM »
Unless you know the mot centre you don't know how  strict they are, I used to go to a mot centre in West Wales who only put my car in the mot bay for the look of things.
Draigflag
« Reply #12 on: March 09, 2013, 09:29:51 AM »
Hmmm...i might know that place! Wasnt in Bala was it?
« Reply #13 on: March 09, 2013, 09:42:20 AM »
Maenclochog. Old boy called Mike, must be retired by now, if he's still alive.
Lloyd74
« Reply #14 on: March 12, 2013, 08:34:45 PM »
Ive had tyres shed their tread like a snake, it was on an old generator, we parked up in the yard and the tyres froze to the ground upon pulling her to move her the treads peeled off. I remember reading an article in practical classics about a year ago the conclusion was old tyres harden off and as such provide less grip and run the risk of peeling as when the tyre rotates at speed under weight the tyre walls dont respond as they should as they are loozing their flex (excellent spelling!) also they advised that when a vehicle is in storage the car should be jacked and propped up to keep the weight of the wheels and stop the tyres squaring off (getting a flat spot). cant remember the exact age they advised replacement at but I think it was 5yrsish, speak to longstone tyres in bawtry nr doncaster these guys will advise you as all they do is classic and vintage tyres and will know all about it and the effects of aging.
I keep modern rubber on my bis as the tyres are 30ish each there not that expensive.
