Author Topic: Bis carb  (Read 1914 times)
wsmitwil
Bis carb
« on: February 15, 2013, 03:39:59 PM »
Hello again
So I decided to start my cars today, the aircooled started first time
Went to start the bis, firstly no starter but with a whack with a hammer it started
Fuel going through, there is spark, and fuel in the float chamber
Spark plugs completely dry, only fires when petrol is poured into the top of carb, and runs for 10 seconds
Car started 3 months ago first time, now nothing, so I think it's the carb
I know it's a long shot but has anyone a spare carb, or ideas on anything I've missed
fiats forever
Bar Vitelli
Re: Bis carb
« Reply #1 on: February 15, 2013, 04:28:59 PM »
Hmmm...
Had a similar non start issue recently with my favourite blue car after I'd left it a while.
It was a few things:
 - the battery was low because it had not been used
 - the settings needed adjusting
 - the spark was not sparking
 - the fuel was not flowing through
The fuel bit is what might be worth checking again, we used a suction device to pull it through and it took a few attempts to get it working without manual intervention.
Not an expert so might not be the right answer - but probably worth a double check.
Every cloud has one...
Re: Bis carb
« Reply #2 on: February 15, 2013, 06:04:12 PM »
If it runs with pouring petrol directly into the carb there is nothing wrong with the ignition circuit, disconnect the fuel line from the carb, put the tube into a bottle or jar, get someone to turn the engine over, If it fills with petrol there has to be a blockage in the carb, If nothing comes out of the petrol pipe it could be the petrol pump :D
Re: Bis carb
« Reply #3 on: February 15, 2013, 06:21:44 PM »
Have you checked the throttle linkages are working properly? Try getting an airline to the jets and blowing them back.
If it does turn out to be a dead carb could you please let me know, I need a bit off of one!!
Cheers Marc
« Last Edit: February 15, 2013, 06:26:05 PM by Hazey-n-Marc »
wsmitwil
Re: Bis carb
« Reply #4 on: February 15, 2013, 07:25:42 PM »
Thanks for the feedback  ;D ;D ;D
Probably a blockage in the carb somewhere
Definataly not the pump, I dident have anything connected to the return and it pumped fuel all over me
See if i can get the carb off tomorrow and break it down, but if it is knackerd I'll be in touch
I might be doing some other jobs on the air-cooled one as 1st and 3rd gear wasn't working and there was an oil leak from the gearbox
fiats forever
Re: Bis carb
« Reply #5 on: February 15, 2013, 08:54:30 PM »
You can check and blow the carb out without taking it off the manifold, What seems to work is carb cleaner in an aerosol it usually come with a long flexible tube that you can direct through the channels and jets.
If you remove the carb you run the risk of damaging the gaskets + the rear retaining nuts are a real pain to take off and put back on ;D
wsmitwil
Re: Bis carb
« Reply #6 on: February 16, 2013, 08:23:12 PM »
Didnt do anything to the bis today as I've been working on the air-cooled gears
Which are still playing up after changing the gearbox  >:(
fiats forever
