When a vehicle is officially scrapped, the vehicle will stay on the DVLA database for 12 months but will probably be shown as unlicensed. The registration number gets recycled and goes back in the pot for re-allocation. Most never get re-allocated though as they go to the bottom of the list. After 12 months of it being scrapped a vehicle drops of the system completely.
If however you purchase a vehicle, and change the registration number for a private plate (cherished transfer) then the registration number also goes back into the pot, and to the bottom of the list. However it is marked, so that when the vehicle gets sold on and a normal registration number needs to be re-allocated, the vehicle should in theory always get its original plate back if it has not already been re-allocated.
Any vehicle that has not been taxed, SORNd, or has not had any activity on the V5 (either name and address changes, or changes of registered keeper) for a long period of time, will usually drop off the system completely including the PNC. The vehicle would then require re-registering. If you have an old V5, then the vehicle is likely to get that registration number back, and if no V5 exists, then the vehicle will be allocated a new registration number from the pot (from the correct year.)
These were the protocols at the end of 2005, and I can't imagine they have changed much.
Tom
(Traffic Geek)
