Author Topic: Is it worth doing?  (Read 1720 times)
Draigflag
  • Got a New Abarth 500 too!
Is it worth doing?
« on: February 12, 2013, 03:54:59 PM »
Last had the oil changed about 18 months ago. Sounds bad, but ive only done a few hundred miles. The car has been sitting in dry storage most of that time, would I be wasting my time changing the oil after so few miles? It still looks fresh and new.
Oh another thing. I want to change the fan belt this year. Are they universal ones? Or do you need a specific one for the 126?
Lloyd74
Re: Is it worth doing?
« Reply #1 on: February 12, 2013, 09:46:10 PM »
 just watched your video, excellent, very tidy, mine is similar in that it is red, but the condition of mine could be described as a testament to the useability of the bis. In fact I would politely describe mine as shoddy and well used, tatty might be another word, I bought it 3yrs ago with the intention of sorting the mechanicals getting it on the road and then sorting any teething problems and then going for a full aesthetic resto, in reality I finished a Rover p5 and then bought a Jowett and upon getting the bis on the road could not bear not driving it every day.
Going back to your question, In my mind if the oils good leave it, the main degradation of oil is the thermal/mechanical conditions of use and if you dont use it then you cant be far off the mark.
Oil manafacturers go on about the ph of old oil and the shelf life not sure if this is to get you to use more! Just make you run her every now and again to get the lube splashed round, and to move  valves so that the springs (valve springs) dont sit in the same compressed state for too long and the springs weaken or the valves stick, warming her up every now and then will also take out any moisture from the engine, which is another thing which may contribute to (BAD) oil.
Again NICE CAR!
124cso
« Reply #2 on: February 12, 2013, 11:07:32 PM »
Even if a vehicle is sitting in a dry shed, if it has been run, there will be contaminants in the oil from combustion. And, even though it is in a shed, unless it is totally sealed and heated, with the seasons you will get changes in temperature and potential for condensation inside the motor.
You should be driving it anyway as cars do not like sitting. Batteries need to be kept charged and without use, brake cylinders stick and do odd things.
Take it for a drive, get it fully hot (20 miles or more) and do an oil change. With the huge oil capacity they have, it should cost you less than a feed of fish and chips !
If you do not use it much, you need to run it an least fortnightly to keep the battery up and I mean DRIVE it to get it hot, not just have it idling to WARM it up as that is probably the WORST thing you can do.
The best way to shorten the life of a lead acid battery is to have it sitting inactive.
Re the fan belt, they are just a generic industrial Vee belt, section is "11A" from memory and buying as an industrial belt will be half the cost of one as a car part. Just take in the old one to get a match lengthwise. I think you want about 810 - 820mm ?
Draigflag
« Reply #3 on: February 13, 2013, 05:30:44 PM »
Thanks people. So one says not to bother, the other says change it?!  When I say its being stored, its actually locked away in a garage, which also has the boiler for the central heating, so it stays consistently warm in there over winter. I removed the car and put it under a carport out the weather, but its only been there a week or two.
Unfortunately, I cant just take it for a nice long drive. Mainly because the roads are caked in salt, grit and at the minute, snow! But also because it's not taxed so getting caught would result in points on my licsense, a fine and possibly the car being crushed! Not worth it! When its taxed in a month or so, i'll be using it a fair bit, that's if i've not sold it (as im buying a new car soonk
DEYAN IYI
« Reply #4 on: February 13, 2013, 06:08:29 PM »
According to "Driving PF126p" (1982) if you don't use the car, changing oil every 6 months ... is a must :$
Well, for the "normal" cars manufacturers usually recommend one year between changes with or without driving if less than 10.000 km.
Not long ago I found an article (in the context of VW Bugs) where optimal time for the next change for air cooled engines was noted as 6 months and for water cooled ones one year or when the counter says.
But...  an over-pious saint isn't pleasant even to God  ;D
« Reply #5 on: February 13, 2013, 06:31:13 PM »
I used to change oil once a year despite circa 800+ miles a year. Visually, the oil looked new, so opted to change every two years. It seemed wasteful changing once a year, but I suppose sticking to the manufacturers recommended oil change in good.
I'm not sure what the Bis recommended oil change is. I'll need to refer to the owner's manual.
