Author Topic: engine out ?126bis  (Read 1553 times)
markbubble
engine out ?126bis
« on: February 09, 2013, 06:17:46 PM »
hi all after having got ourselfs a 126 bis thats been sat around for about 10 years im going to give it a damm good check/service,i want to do oil,coolant,plugs filter etc etc but wonder if its better to pull engine out to give it a good clean and proper engine flush etc?whats your toughts on this plz? if its out is it worth taking head off and decoke,ceck everyting etc(heard there prone for head gasket failure?)
any help/advice be great,iv striped loads engines from moped to v8s so it doesnt faze me to do it just wonder if it needs it or not
cheers mark
Re: engine out ?126bis
« Reply #1 on: February 09, 2013, 11:25:14 PM »
Hi Mark,
All the service items you have listed can be done with the engine in place, even removing the cylinder head :thumbup
If there are no engine/gearbox problems or oil leaks its better not disturb anything, we've all been there where a simple job turns into a nightmare with old cars due to seized nuts, bolts, and parts, a simple service can turn out to be very expensive ;)
markbubble
« Reply #2 on: February 10, 2013, 06:32:36 AM »
cheers,your right a seized bolt or similar can make things worse ,sadly the weather today meens i cant do much on the car but il have a quick look around and get some parts ordered ready :)
« Reply #3 on: February 10, 2013, 01:35:53 PM »
I agree with Pete. In addition, check that the radiator fan works automatically!!!!!!
markbubble
« Reply #4 on: February 10, 2013, 01:41:37 PM »
cheers i will check fan works,im planning on full flush and new coolant etc,is it worth taking head off and check it over and new(been told copper) gasket? or leave alone
« Reply #5 on: February 10, 2013, 01:50:43 PM »
If it aint broke don't fix it.
