Author Topic: Right... decisions decisions  (Read 2853 times)
Tommo32
« on: March 20, 2006, 11:11:49 PM »
im testing the water here with my ideas, so please bear with me till i gain some more knowledge of these little monsters.
right, come next summer im gonna be wanting an aicooled 126, i dont want a BIS as i prefer the idea of an aircooled engine (ive dealt a lot with vw beetles) and ive heard of bis reliability issues. anyway. i will be looking to uprate my engine, mild porting etc but what i want to now is what is available off the shelf and where and also what are the popular mods (obviously K&N's an stuff go without sayin) also does anyone do big bore pistons? are engine parts expensive? easy to get hold of? obviously with a 'hopped up' motor im gonna want it to run nice an cool, so is it easy to modify the fan so it can give better airflow? im presuming it runs from a belt so does anyone make overdrive pulleys for the fan?
  ah yeah... bumpers, now i dont like the big numb plastic thing glues to the front of most 126's, i would be looking to bin it completely and plate up holes/smooth off lumps maybe even fabricate a valence with a bit of a lower stance is this popular? anyone got any photo's? i wouldent mind early bumpers but im guessing these are hens teeth no?
  last thing... rear light clusters, i think they look very, well... 80's. are there any more popular mod's in that department? i was thinking of fitting mini tail lamps or summot im not sure, it all has to look fairly factory anyway because i dont want to have to pay the insurance of a 'modified' car. oh the very last thing... what do the standard steel wheels look like with no wheel trims??? are they just plain with no holes in or awt? if so thats good.
sorry for all the questions but any help will be much appreciated.
Tommo
« Reply #1 on: March 20, 2006, 11:31:25 PM »
hi tommo, wooo where do i start lol  :lol:
with aircooled mods, firstly many people fit larger abarth oil sumps, this helps to cool the engine, they also fit, sports camshafts, sports exhaust, dellorto carbs, abarth rocker cover. These are all fairly inexpensive, if you know how to fit them. You can also get 800cc bored for the 650cc engine, With regard to alloys, they do cromodors with the same stud pattern. Also can go for lowered suspension. I dont know if you aware of the fiat 500, but the 126 engine is practicaly the same but uprated, so alot of tuning parts are interchangable. I put a good site below for you to look through, clikc on links, and look at all the other sports parts sites.
Speak to a guy called dave on here, he is in Jersey Channel Island, and has a yellow 126 aircooled. his forum name is 126dave.
http://www.fiat500sport.com/def.asp?l=ENG&sku=1419001675
regards
richard
aircooled wanted.. i got one
« Reply #2 on: March 21, 2006, 07:04:52 AM »
hey tommo , ive got a aircooled for sale
message me
PaulB
« Reply #3 on: March 21, 2006, 03:52:59 PM »
The cylinder head from the aircooled Fiat Panda 30 is more or less a straight swap for a 126 head (so long as you've the necessary shorter pushrod tubes) and that, along with the stock weber carb on the Panda, will take your BHP up by about 25%. The Panda 30 head needs to be sourced from mainland Europe, but is not expensive.
The FSM built 652cc aircoolers also had a better engine than the earlier 652cc italian built ones - better cam and compression so more grunt. Also if you want performance, avoid the early 600cc ones.
A wider bore exhaust can also add a few BHPs.
The existing fan should cope well with road use, but if you are set on thrashing the engine to glowing point then a larger sump and oil cooler is the way to go as the fan will do little after a certain point. Also, replacing the original fan with a single piece aluminium one will stop it flying apart as the revs go in the red. As well as helping the cooling, alu sumps stiffen the crankcase to some extent.
Fifth gear is a very desirable but expensive option to keep revs down at 'speed', but a 126BIS gearbox or just crownwheel and pinion will do a similar job so long as you have extra BHP to deal with lower torque.
Balancing the engine should help, but how much in these engines I'm not sure - they're not exactly V8s.
The brakes will need upgrading - discs are readily available cheaply from the EU from places like Ruud's Garage in Holland.
have fun
Tommo32
« Reply #4 on: March 21, 2006, 06:54:00 PM »
wow thanks guys. im not looking to go balls out on the motor just a nice balence between usable performance and whilst keeping it reliable.
Thanks for the offer but im not planning my 126 for a while yet till ive saved up as i have just bought another bike which is my current pride and joy and i refuse to sell it.
the aftermarket parts sound great, im not bothered about alloys im just curious about how the stock steelies look as its all part of the design (all will be revealed in the future)
paul harbinson.
« Reply #5 on: March 24, 2006, 08:07:03 AM »
I posted a note for a place in Germany that is must for modifying.www.fiatclassic.com.They even do five speed gearboxes for the 126.
Dante Giacoso, pure genius!
