Author Topic: Pertronix Ignitor Kit for (Marelli S152 Distributor) (126)  (Read 3368 times)
« on: March 18, 2006, 12:04:01 PM »
I received this email from middle barton garage about this ignitor kit. Sounds ok good, but i dont know muchx about them.
"Chris,
We currently have a special offer on with our Pertronix Ignitor Kit for Italian Air-cooled Fiat 126's (Marelli S152 Distributor).
We have twenty kits available at £99.99 each plus VAT (usual price £125 plus VAT).
The kits consist of the sender unit and collar which goes inside the distributor (negating the need for the points/condenser etc).
If you need any feedback on the performance of this item please contact John Bitmead ( as he has been testing one for the past few months).
Can you put this info on your site?
Julian
Middle Barton Garage"
fiatfsm
« Reply #1 on: March 19, 2006, 12:30:12 PM »
Just one thing, as with any electronic ignition device, when it fails you are stuck! They do fail, and IMHO a properly set up points system is far more reliable and if that fails, is easy and cheap to fix.
« Reply #2 on: March 19, 2006, 05:31:45 PM »
yer you might be right there Barry, these are only fr the original italian aircooled 126's anyway.
Hudson Henry (Nigel) has one from a motor bike in his 500 with 650. I think he thinks it makes the car more reliable.
regards
hudsonhenry
    • http://www.retro500.com
« Reply #3 on: March 19, 2006, 08:25:24 PM »
True, when an electronic ignition fails you are stuck, but the same can be said for when the condencer packs up when using the standard system, an all to frequent problem with 500 and 126's or if the points pitt too much.
The electonic ignition units provides maintainance free running, no adjusting points and no condencer to worry about. For the average non- mechanical person its well worth the upgrade. Starting is much easier as well.
I have heard good things about the Pertronics system and the price isn't bad either (please don't take this as my recomendation of MiddleBarton Garage), but its also worth looking at the luminition system or the Boyer Branson system that I use, which is a half way house - developed for classic british motorcycles, it despences with the condencer completly and uses the points as a low voltage switch- the high voltage going through a little black box. With no high voltage going through them the points wear out at a fraction of the speed and in the last three years I have not had a single problem (but still have the same points).
fiatfsm
« Reply #4 on: March 20, 2006, 09:38:42 AM »
yes, but if a condenser fails its 3 or 4 quid and easily replaced.
PaulB
« Reply #5 on: March 21, 2006, 04:18:58 PM »
I had the system from MBG in my 126 and it was great - started up with one pull at sub-zero, ran smoother and so on. It died because a piece of metal found its way into the dizzy and stuck to the magnet, ripping a hole in it as it spun - can't see that happening too often, whereas points close, the condensers fry, the caps track, etc, usually on a motorway or a six lane roundabout (I've probably said this before, but I had a police escort as I pushed my 500 off a motorway roundabout near Bristol due to points closing - funny now but it was one of those near death experiences I don't want again).
 I am now back on points, but I'm using a new dizzy and keep a spare in the car - its easier to swap a dizzy than mess about trying to work out points/condenser, and either way the timing needs setting.  I'll do the same when I go back to electronic - keep my other dizzy in the boot as a spare, so if you have an FSM engine, then just by an Italian dizzy and keep the Polish one as a back up - I got a NOS distributor on ebay for £10. MBG also told me they were on the case with the Polish ones - creating a universal kit, which may be why they are selling off their current stock?
I also use the great Polish twin spark coil which is bullet proof and gets rid of the cap and rotor.
BTW, MBGs system is also a halfway house as you keep the coil. Also worth noting that on an FSM with twin spark, you either need to move the ballast resistor to the engine compartment, or run wires to the boot, as the system needs to take the (+) before the resistor.
jabeoo1
Re: Pertronix Ignitor Kit for (Marelli S152 Distributor) (126)
« Reply #6 on: May 11, 2011, 10:10:27 PM »
My distributer cap/points/rotor arm are what seem like the major pain in my fiat 126's ass.  Is it just me or is it the same for everyone who owns older cars? Every few months the first sign of a small occasional misfire creeps in.  This is followed at any point in the next month by a decline over about 20 miles to an engine having the human equivalent to a heart attack.
Any up to date thoughts on the Pertronix?
I have spoken to these guys today and they have full kits with coil for £180 including VAT.  The new system is apparently a lot better than the earlier designs.  I asked outright what teething problems they had so far.  They replied that they have yet to hear from anyone with a problem.
I am considering it but really wanted to get some up to date info direct from users.......Anyone out there thinking the same as me??????
« Reply #7 on: May 12, 2011, 10:13:37 PM »
Thought I replied to this... must have dreamt that :$
I have tried a well know brand with a numerical name. It has not been unreliable, instead it has advanced the ignition too far overheating the engine causing the head to crack between the valves >:(
A spare dizy doesn't cost an arm and a leg, I keep one with a set of good points and condenser under the hood so who cares about something going pop, as long as you can get home  :P
Timing changes as the points wear, they bounce, they can miss so electronic in theory has to be a better option, in my humble opinion as I am sure someone will tell me I'm an idiot for saying that... just which option is going to do the job properly.. Either my snap-on timing light tells lies, possible, or the well known numerical named electronic ignition is programmed wrong, or I'm an idiot and have not grasped the theory of how far advanced a spark whould be on a 4 cycle engine..funny it seems to run normal temp on points..
I have tried my electronic ignition again, set it to fire at TDC at idle, and if my timing light tells the truth it still seems to advance more than 30 degrees  >:(
That Pertronix has to be better than the one I have  ;D
