Author Topic: Anyone else's 126 Freezing up?  (Read 1745 times)
Blonde126
« on: December 11, 2012, 03:56:59 PM »
I'm not sure if there's something up with my 126, it's really cold and the glass on my 126 is not only freezing up on the outside, but in parts on the inside too! The door locks continually freeze, the windscreen wipers freeze to the windscreen and sometimes the doors/bonnet/boot freeze shut too :S
I just don't get it, in Poland where their winters seem to be a lot worse than here in the UK, they don't seem to have any issues??
Re: Anyone else's 126 Freezing up?
« Reply #1 on: December 11, 2012, 06:11:39 PM »
Poland. Never leave you handbrake on. Also Poland is colder but a dry cold, not damp like in the Uk.
I spray silicon spray in my locks and petroleum jelly on door seals. Fogging up inside, leave a couple of packs of silica gel on the dashboard. I cleverly removed my roof lining, so the condensation drips on my bald head too ;D
Bar Vitelli
« Reply #2 on: December 11, 2012, 09:53:21 PM »
I know funds will probably be tight in the run up to Xmas but if you can't get indoor parking then it could be worth investing in a car cover (or getting someone to buy you one for Xmas!), don't go for a cheap one, the one I use is lined with a soft lining and really does help protect it without all the usual condensation issues.
If you park on the road you can probably get away with putting some reflective tape on it as long as it's not too buy a road?  Will save you a lot of hassle and will help protect your car through winter.
Let me know if you are interested and I'll ping you details of my supplier.
Every cloud has one...
« Reply #3 on: December 15, 2012, 01:53:18 PM »
The defrosting on the inside is all part of the "126 experience"!! i found that i had to scrape off the ice as it built up with an old AA card on the inside as i drove along last Tuesday night! i now think i should refit the thermostat tin and piping before it gets any worse!
« Reply #4 on: December 15, 2012, 04:00:10 PM »
A car cover definitely helps. I also put an old bedsheet (with elastic ends) which cover the top bit of the car down to window area. Ricambio sell a v.g. covers specifically for 500/126. I bought three from him for each of my 126s. Because of the cover, it does not appear to freeze behind or inside windscreen. I think Bar Vitelli also sell car covers as well.
Try spraying the door locks with WD-40, it definitely works. Make sure the thin plastic straw goes into the locks. Let the lubricant work through the inside of the locks.
« Last Edit: December 15, 2012, 09:29:05 PM by Amateb8 »
« Reply #5 on: December 15, 2012, 04:23:45 PM »
My DeVille lives outside with no cover. I used it twice earlier this week when the weather was bitterly cold. Apart from the ice on the inside screen small lumps of ice had formed on the inside of the sunroof. On the first trip I drove 15 miles and still could not wind down the windows as they were frozen solid. On the second trip the doors were frozen shut but you have to be a bit careful as if you pull at the top of the door frame you can bend it out so best to pull on the bottom section. Much milder but wet on friday & did a 40 mile trip. Got stuck behind an HGV which chucked loads of muck up onto my screen. Pressed the rubber screen washer button which went in and did a little squirt then it stayed in. The washer bag was still frozen solid and did not thaw out till late afternoon  :$
Blonde126
« Reply #6 on: December 16, 2012, 02:49:18 PM »
Thanks for the advice everyone :) I've put vaseline (unfortunately I only had rose flavor at hand but at least it smells nice) on all the seals, including the bonnet and rear hatch. Also put some WD-40 in all the locks :)
However since I've done all that prep, it's not been icy cold since which is good cos I have an hour and a half road trip this Friday on the A69 and would rather it stayed ice and snow free!
ronb1967
« Reply #7 on: December 26, 2012, 11:54:59 PM »
Hi Blonde126
just a quick note to say that vasaline is petrolium based and for that reason is not suitable on rubbers longterm as it will perish the rubber in time, the best thing to use is a silicone spray lubricant as this is safe to use on rubber and does not leave a residue, silicone spray is not the same as WD40, they are 2 different products, so WD40 in locks and silicone on all rubbers, and a message to all out there please unstick you wiper blades from the screen before you try to clear your screen with them, as you run the risk of burning out the wiper motor or breaking the wiper linkage if you try to use them whilst they are stuck to the screen
« Reply #8 on: December 27, 2012, 12:34:41 AM »
Definitely go for a car cover. There have been a lot of debate regarding the pros and cons of car covers. But I think the positives outweigh the negatives particularly if you do not have a garage, and if you take some precautions, e.g. I remove the cover when the weather is dry to air the car a bit. If the car gets wet, wipe off the water thoroughly from the bodywork (and other areas where water can build up) before putting back the cover. It protects the car from the elements, plus during cold weather, stops the windscreen from freezing up and at the same time protect the wipers.
