Author Topic: Charging system  (Read 1461 times)
Charging system
« on: December 03, 2012, 10:42:38 PM »
Hi all, I have a problem with the charging system. The car starts OK, after about 10 miles with the heater motor on along with the side lights and window wipers, going slowly, the electronoic rev counter plus my radio and dash lights go off.  If I switch the lights and heater of the rev counter and radio come on.  Also if I rev the engine the lights brighten then dim as the revs increase.  Anyone any ideas
DEYAN IYI
Re: Charging system
« Reply #1 on: December 04, 2012, 08:32:43 AM »
Well... It happens to the 126 since 1972...  :$ No matter if it's the newer model with the alternator, you will not be able to use all the consumers together or only as long as the battery can recover the lack. So, first of all, forget about the radio...
According to the books, the alternator starts charging the battery with 13,5V from about 1300rpm when 25*C.
Check the belt! Probably slipping.
« Last Edit: December 04, 2012, 09:13:18 AM by DEYAN IYI »
