Author Topic: Cinquecento seat belts  (Read 1529 times)
yorker740
« on: November 09, 2012, 01:15:46 PM »
Hi, does any know if front seat belts from a Cinquecento will fit a bis?
popik81
Re: Cinquecento seat belts
« Reply #1 on: November 09, 2012, 11:10:14 PM »
front ok back not sure but 99%yes
« Reply #2 on: November 10, 2012, 07:21:53 AM »
Please check this thread out re Cinquecento seat belts.
http://club126uk.co.uk/smf/index.php?topic=2171.0
Funkin Go-nut
« Reply #3 on: November 15, 2012, 03:44:35 PM »
got the fronts on mine, but found that the inertia reel only works if its 100% horrizontal so I moved the mount from behind the cover to floor mount behind the front seats using the L shaped brackets. The mounts at the other end had to be flattened so they sat correctly on the centre tunnel. All fine and 2 MOT's passed with them fitted.
