Author Topic: Coilovers  (Read 1844 times)
fiat126fzr
Coilovers
« on: October 30, 2012, 10:09:49 AM »
Hi, I've had a search for the past couple of weeks and decided I need to go down the coilover route. Could someone please provide me with links to sites that sell kits so that I can see if its worth investing or more cost effective to have a set up fabricated. Cheers
pietschokkenbroek
Re: Coilovers
« Reply #1 on: October 30, 2012, 12:48:09 PM »
Welcome Fiat126FZR (interesting name! ;D FZR as in Yamaha FZR??) Maybe this can be of any help:
http://www.fiat500ricambi.nl/tuning/Ophanging
Please let us know what you're up to!! 8)
fiat126fzr
Re: Coilovers
« Reply #2 on: October 30, 2012, 02:43:57 PM »
Thanks, that's the sort of thing that I was after. Yeah I'm rebuilding a 126BIS with a Yamaha fzr 1000 exup engine. Engine and transmissionwise i'm sorted but will have a few questions to ask on here in respect of braking systems and suspension in the up and coming months.
fiat126fzr
Re: Coilovers
« Reply #3 on: October 30, 2012, 05:57:21 PM »
Also AVO Coilovers keep cropping up in searches, has anyone got a part number for their shocks at all?
Is there anyone on here running a coilover set up of any kind as it would be handy to chat to you!
Re: Coilovers
« Reply #4 on: October 30, 2012, 10:25:30 PM »
Welcome to the forum, I think we would all like to be running a better front suspension ;D The standard suspension isn't Ideal but its cheap to produce, That said 126 wasn't designed to be a performance motor :D
The kits to me are overpriced anyone with good fabrication skills should be able to put something together, As for coilovers I would checkout Ebay for heavy duty quad bike shockers [CLICK HERE]
fiat126fzr
Re: Coilovers
« Reply #5 on: October 31, 2012, 09:44:39 AM »
With changing to a front coilover set up would this be seen as 'substantial mods to chassis' and constitute a VOSA IVA?
Would quad shocks be up to the job? I suppose as long as the spring and damper are high ratings as there isn't exactly much weight up front. It is a massively cheaper idea...
Re: Coilovers
« Reply #6 on: October 31, 2012, 07:47:51 PM »
Your not actually cutting/changing the chassis or monocoque if you fabricate something on similar lines to the kits that are available,
They simply bolt on to the cross-member where the original spring mountings are located,  as for using quad coilovers I can't see a problem using them as long as you select the correct length and poundage, But that would depend on suspension travel and what bottom "A" arms you use or fabricate,
