Author Topic: MoT Pass  (Read 1673 times)
MoT Pass
« on: October 26, 2012, 05:57:47 PM »
My 126 Bis passed BUT with the usual advisories:
-Nearside front wheel bearing has slight play
-Offside front wheel bearing has slight play
-Exhaust has minor leak.
I have had these advisories year-on-year. It has been MoT'd by the same chap for the last four years. He is aware that there should be a bit of "play" in the wheels but placed the above on advisory to cover himself and the garage. The third advisory is a new one. I wonder whether I should weld the small hole or just buy a new exhaust.
« Last Edit: October 26, 2012, 06:57:20 PM by Amateb8 »
Re: MoT Pass
« Reply #1 on: October 26, 2012, 06:44:26 PM »
Well done mate  :) Always good to get a result. On the subject of wheel bearings I used to take my '47 Sunbeam Talbot to an old village garage (strangely run by the elder brother of the garage I go to now) as they were used to old motors. I had just fitted new wheel bearings and set them up as per the workshop manual. The guy failed them on the MOT . Went home and overtightened them . Went back & got the MOT . Returned home and reset the bearings as per manual  :)
If the exhaust is perforating then it is on the way out . If it is cracked or split then welding may be OK.
Re: MoT Pass
« Reply #2 on: October 26, 2012, 07:24:52 PM »
There is a very small hole in the pipe over a centimeter away from were it joins the exhaust box. I might get it welded or or braised if the metal is too thin? As a stop gap, perhaps, getting a repair kit as well.
http://www.ebay.co.uk/itm/120777372162?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Re: MoT Pass
« Reply #3 on: October 26, 2012, 07:41:00 PM »
If you are going to have it braised then i would suggest a very long slow cook , plenty of onions, carrots, swede, a sprig of mixed herbs, plenty of good stock and a glass of red wine  :)
Still might be a little chewey though  ;)
Welding might be good but brazing might accelerate bi-metalic corrosion  :$
Re: MoT Pass
« Reply #4 on: October 26, 2012, 09:16:36 PM »
Thanks Rusty. I wonder whether Kwik Fit still sell 126 bis exhausts.
Re: MoT Pass
« Reply #5 on: October 26, 2012, 10:22:58 PM »
I have looked everywhere for these and when you take postage into account Ricambio are the only people, original quality and made in Italy.  I asked him to find me a Stainless one, he tried but to know avail..... :(
Re: MoT Pass
« Reply #6 on: October 27, 2012, 08:30:13 AM »
 Maybe it would be worth contacting the 126Fan guys, if they had a big enough order they could probably get some in from Poland. I know they don`t keep them in stock as there isn`t much demand for them.
 They also have got a somewhat modified exhaust on they Pop convertible which is based on the bis.
 The ones from Franco work out nearly £130 + postage. I remember Marckymarc had a stainless one made for about £250 with a lifetime guarantee which might be a better option.
Re: MoT Pass
« Reply #7 on: October 28, 2012, 08:13:46 AM »
Many thanks all. Lad, would be interested in the modified exhaust used in the Pop, but will it need modifying to fit the bis?
