Author Topic: Headlight question  (Read 1579 times)
Headlight question
« on: October 10, 2012, 06:33:55 PM »
Is a fiat 127 headlight the same as the 126 (All Models)?
Re: Headlight question
« Reply #1 on: October 10, 2012, 08:44:24 PM »
Not all 127 headlights are the same, I think only mk 1 and mk 2 are the same.
« Reply #2 on: October 10, 2012, 09:18:20 PM »
The headlights of the 127 are the same shape, but do not have sidelights like the 126.
« Reply #3 on: October 10, 2012, 10:46:13 PM »
Thanks, if you fitted two 127 lamps would the sidelights not being there be a MOT requirement or are they only tested if they are fitted?
« Reply #4 on: October 11, 2012, 08:30:35 AM »
1973/126 has had a 127 or two, they would probably know if the 127 lights have the mounting point for the sidelight. You do have to have sidelights for the mot, it is probably quite easy to drill a hole in the reflector to take the side lights, or maybe split the indicators into sidelight and indicator.
« Reply #5 on: October 11, 2012, 08:01:19 PM »
I would not risk trying to drill the reflector. It will shatter!
