Author Topic: Project 126 Aygo  (Read 76614 times)
pietschokkenbroek
Re: Project 126 Aygo
« Reply #105 on: February 24, 2017, 03:04:11 PM »
Great clip, Great work, but we need to see it running ;D
 :secret:
[youtube]https://www.youtube.com/watch?v=Cvp4-UM0RV4[/youtube]
« Reply #106 on: February 25, 2017, 01:28:03 AM »
Hey Piet the new tablets must be working :P Should be ready for RR this year ;D
skoda_norman
« Reply #107 on: February 26, 2017, 09:05:24 PM »
Woo! I was talking to DeVille Chris about this car only last week. So please to see some updates!
pietschokkenbroek
« Reply #108 on: March 05, 2017, 04:23:12 PM »
Thanks Rob, I know it took me way too long...
Hey Pete!, RR17 :headscratch:?
Spring is in the air the sun is out, the sound of birds and angle grinder.  ::)
Hopefully this will be in epoxy primer by the end of te week...
pietschokkenbroek
« Reply #109 on: August 05, 2017, 07:22:30 PM »
If you experience a complete lack of structure to this build.... you are absolutely right, so am I.... ( ??? :P)
Some pictures:
Epoxy primed the inside. (makes it look more tidy   ;D  ) When I get under the car and find rustholes to big I will tackle them, for now I leave them as is.
We played around with a Raspberry Pi combined with a OBDII interface-thing. We're able to get readings of temperature, revs etc. Hopfully we can use this to incoporate in the dash...I need my computerprogrammer friend to do this!
We added some sexy stuff to the (front-) suspension...
Right now I am rebuilding the front suspension and steering...
Thanks for watching!
pietschokkenbroek
« Reply #110 on: August 05, 2017, 07:26:10 PM »
And we did some extensive test driving round the premises :D
[youtube]https://youtu.be/VDjXqDbDyoo[/youtube]
Gadge
« Reply #111 on: August 05, 2017, 08:03:49 PM »
Fantastic conversion buddy :thumbup has to be the best and most practical engine swap I've seen yet  :D .......... Why people mess around with bike engines I'll never know
FOR LACK OF A BETTER NAME
« Reply #112 on: August 06, 2017, 08:50:57 PM »
Fantastic Piet, nearly there :)
Flying Carpet
« Reply #113 on: August 08, 2017, 11:12:50 PM »
Wow!
Only just come across this build, but amazing work Piet, great engineering.... and perseverance!
Oh, and that vid is delight, especially at 1:29 - LMAO!
Well done!
pietschokkenbroek
« Reply #114 on: February 05, 2018, 08:18:59 PM »
 :)Thank you all!  :D
Still working on it, not as much progress as I'd hoped for  ::)
I'm converting the front brakes to Aygo disks...
pietschokkenbroek
« Reply #115 on: February 11, 2018, 08:20:04 PM »
Upgrading the front suspension and brakes has kept me bussy the last few months. As I may have mentioned before, the Aygo parts are been made available by my project sponsor  :D. So for me the challanges of getting them to fit  ???. Originally these brakes are fitted inside a 14 inch wheel, I want to try and make them it in an 13 inch rim....
I can tell you that's tight....
First I changed the front hubs to the newer type, with 4x98 PCD.
Made templates out of plywood...
made brackets from steel
And hey presto  ;D
it all seemed to work, except that brake fluid was leaking from the brake pedal on the floor. I hope that a new master brake cylinder improves this... ;)
pietschokkenbroek
« Reply #116 on: October 11, 2021, 08:53:05 PM »
finally, sorry it took me ::) so long. I've been working on the car occasionally.
I reinforced and finished the engine mounts
The rear wishbones are powder coated and fitted with new bushings
Installing the new wheel bearings was a !@#$%^ job
the engine has been placed again (engine compartment has already been painted green).
To boost morale I wanted to start with the outside (long story short...
We are going to tackle the spraying work in stages. Well, it's not perfect, but I'm super happy with the result
« Reply #117 on: October 12, 2021, 07:11:31 AM »
Looking good Piet, should be finished for next years shows  ;D
pietschokkenbroek
« Reply #118 on: August 23, 2022, 11:41:26 AM »
[youtube]https://www.youtube.com/shorts/61CUZRs8Ij0[/youtube]
silly season / "cucumber time"  :D ;)
Bar Vitelli
« Reply #119 on: August 23, 2022, 06:53:29 PM »
Stunning! 😍
Every cloud has one...
