Author Topic: Bis carb  (Read 2047 times)
wsmitwil
Bis carb
« on: September 22, 2012, 04:32:25 PM »
Hi everyone just wondering if anyone can get detailed pics of their own bis carb as the carb on my bis looks messed around with and I cant actually find a carb that looks like mine, I'm sure it is a bis carb but it's just not working at all the chokes not working butterflies on top don't move and it's just keeps backfiring wildly
Help  :cry:
fiats forever
Re: Bis carb
« Reply #1 on: September 22, 2012, 05:24:13 PM »
Hi, If the engine is back firing the carb must be working as its putting fuel into the engine, Check the points first and then reset the ignition timing, If you have had distributor out. align the pointers on the front pulley to the 10 btdc - Remove the distributor - put the car in gear and push it forward one full turn till the timing marks align to 10 btdc again - drop the distributor back in and time up.
The Butterflies at the top of the carb only open and close with the choke cable.
wsmitwil
Re: Bis carb
« Reply #2 on: September 22, 2012, 05:48:35 PM »
Thanks  for the speedy reply, great advice, re butterflies - they dont seem to open when i pull the choke
heres some photos
butterflies taken out on first two photos
Nothing else has been removed on this carb what you see is what I got
« Last Edit: September 22, 2012, 06:10:18 PM by wsmitwil »
fiats forever
Re: Bis carb
« Reply #3 on: September 22, 2012, 06:29:11 PM »
This may Help ;D
wsmitwil
Re: Bis carb
« Reply #4 on: September 23, 2012, 08:47:34 AM »
Hi thanks for the pic, looking at it there are a few differences between that and mine, for example the exterior diaphragm where as mine is part of the carb seen in pic 3 o the far right where ther does seem to be parts missing, I've herd there are two different carbs
fiats forever
Re: Bis carb
« Reply #5 on: September 23, 2012, 09:15:19 AM »
Re: Bis carb
« Reply #6 on: September 25, 2012, 08:14:26 PM »
I think you have some bits missing that operate the choke, they are a mixture of metal and plastic parts and the plastic parts perish with age, mine are missing and have found it very difficult to fine replacements.  I run with no choke at the moment.
Heres the bits I mean the pic has a red background, it is the bar that operates the butterfles at the top
http://club126uk.co.uk/smf/index.php?topic=4398.0
Da Londo
    • Fiat 126 blog
Re: Bis carb
« Reply #7 on: September 26, 2012, 11:24:07 AM »
