Author Topic: kingpins?  (Read 2917 times)
kingpins?
« on: March 05, 2006, 11:20:52 AM »
i went out this morning and have developed a sloppy steering and a lovely creaking noise , i was throwing the car around in the little lanes near me . king pins? can i chuck some used ones on as i have some on another car?  :?:  :smt029
kingpins?
« Reply #1 on: March 05, 2006, 01:07:51 PM »
No problem replacing them from another 126, but use the whole stub assembly from the other car. You may have to check the tracking after!
fiatfsm
kingpins?
« Reply #2 on: March 05, 2006, 04:38:09 PM »
sounds more rack or track rod end based. never found kingpins to do anything but clonk when worn.
paul harbinson.
kingpins?
« Reply #3 on: March 09, 2006, 07:58:18 AM »
If the steering is tight to turn it'll be a seized bush.Mine suffered the same symptom's (in fact it's still a wee bit tight)plenty of grease and use a persuader (hammer) last resort is a wee bit of heat to get the grease through the bush.
Dante Giacoso, pure genius!
PaulB
kingpins?
« Reply #4 on: March 09, 2006, 04:21:44 PM »
Its easy to check if its king pins - jack up the front end, grab the wheel top and bottom and try to rock it in and out - if you feel more than a little movement then something's amiss. King pins will allow the wheel to rock top and bottom and movement is usually visible on the stub axle. Too much endfloat and the wheel will also rock side to side. Also could be loose wheel bolts but they be easy to spot. As well as previous suggestions, common causes of sloppy steering are wrong tyre pressure, bad tracking/geometry, worn shocks, etc.
