Author Topic: It's a Drag , Logging in a 126 !  (Read 2149 times)
« on: September 05, 2012, 12:01:25 PM »
So with winter coming and aware that the log pile for my little wood burning stove was quite low I had been keeping a mental note of fallen trees & large branches that I have spotted on my travels  :)
So I have been enjoying going out in the 126 DeVille all this week in the sunshine. Popped to the shops then had a bit of trouble with the starter motor again but got it fired up OK.
I went to a car park on a country lane and parked up on a steep bit next to where a tree had fallen. Idea being that I could just bump start the car if I needed to. Got my cordless electric chainsaw out and cut some good size lengths of timber and put most of them in a bin liner. Opened the drivers door and half chucked them across to the passenger seat well.
Thing is the long ends, instead of landing on the seat, stopped short landing on the handbrake  :$
Gravity is a wonderful thing, it keeps your feet on the ground  ;D Unfortunately it also makes unbraked vehicles accelerate rapidly down steep hills  :o
I just managed to dive headlong and get my hand on the front of the driver's seat with my knees being dragged over the rough stones. I can remember an instant feeling as the speed built up that I had lost it and was going to have to let go when the car seemed to hit a couple of bumps which gave me the chance to grab the handbrake handle with my left hand. Got the little blighter stopped  ;D :D ;D
A lady walking two dogs was right there "Are you OK?" I explained what had happened. She then said "You left a log back there" . I thought that she was having a cheeky joke but when I looked back up the hill I could see that I had not put the longest log in the car yet and I realised that it was that log that slowed the car down when the wheels went over it and saved the day  ;D
Another guy came over with his dog "I saw what happened , are you Ok?" then he said "They do say that a shock a day is good is good for your heart" . Strange the folk you meet when you are being dragged downhill by a runaway car  ::)
Anyway both these people were holding plastic bags with little "Dog Logs" in them so I guess it must have frightened the dogs as well  :P
Re: It's a Drag , Logging in a 126 !
« Reply #1 on: September 05, 2012, 12:05:12 PM »
You might be better off with a roof rack, used to logging in my polo like that.
eben80
    • AircooledVWSA
« Reply #2 on: September 06, 2012, 09:55:31 AM »
Cool story..
My load didn't fit in the Fiat....  ;D
« Reply #3 on: September 06, 2012, 08:20:45 PM »
Yes "cool story" but I managed to warm it up a little bit today  :o
Frustrated by the idea of not going out in the 126 on another sunny day I thought that I would find a suitable stick that I could push on the lever on the pull starter motor just in case the problems were down to the cable. If you are running an aircooled with a pull start you can do that if the cable breaks  :)
So found a stick , gave a push and saw a large spark. Strange I thought but had a look then had another go , huge spark then a small fire  :$
Turned out that the slack starter cable arced out on the starter main feed contact , melted the cable and welded itself to the terminal on the starter motor. Managed to blow out the flame then wondered what that red wire was ?
Actualy it was the starter cable glowing red hot as it was a direct short circuit from the battery. Seems that the insulator cover on the motor had fallen off along the way. Car was filled with smoke so yet to check it out. Too much excitement in two days  ;)
eben80
    • AircooledVWSA
« Reply #4 on: September 07, 2012, 02:23:42 PM »
Welcome to the club... I've done that twice  :$
I use a short broomstick... especially handy when you are tuning the engine and don't want to run to and fro all the time.  Make sure you have the rubber insulator on that live terminal and you should be OK.
« Reply #5 on: September 11, 2012, 07:03:09 PM »
OK so never do it witout a rubber  :D
So is working on the starter motor on a 126 the worst possible job  :cry:
I have been on it all day and still more to do. Can't use my ramps as my 500 is on them with half an engine in. So trolley jack at the rear , exhaust heat shield and rear wheel removed to get access. The starter motor would work sometimes OK , sometimes engage , drop out and just whirr & sometimes it would just whirr and not engage. It took a bit of abuse when I had fuel problems and had to use the starter motor to move the car when I got stuck in some awkward spots. I thoiught that I may have burnt out the copper contacts in the pull start switch on the motor. After a struggle I fitted a new switch in situ but sadly still the same. The good news was that I got the engine started and the battery had stood up to the extended dead short when the starter cable lit up like the element in an electric fire  ::)
Starter motor had to come out  and if there was swear box close by it would have had a good day  :o
« Reply #6 on: September 17, 2012, 05:15:33 PM »
Just to put this one to bed. My knees have not healed up yet but the car has been back on the road since last week and all is well. I had a starter motor that I bought on eBay as a recon unit. It was a little scruufy on the outside and when I came to examine it more closely the pull start switch was totaly seized up and for some reason there was a load of crud inside the motor. I think it had been stored in a very damp place. So total strip down , sheared off little screw that held the switch, fix and clean up then fit to car. Had to bodge up the cable but net result is a starter motor that really kicks the engine over quickly. So excellent starting and much improved hot start. The only thing I could see wrong with the old motor was a fair bit of brush wear and the bearing (oilite bush) quite worn at the brush end.
Might get some more logs this week  :$
