Author Topic: oil change procedure  (Read 1563 times)
jdobson
« on: August 17, 2012, 01:30:40 PM »
Hello Everyone. could any one enkighten me on the procedure of changing the engine on my BIS.  I know about the sump plug, and have a new oil seal gasket. Do I have to remove the rear bumper and panel to access the thrower? Regards. JOHN PS  I'll get my head around this car one day.
Re: oil change procedure
« Reply #1 on: August 17, 2012, 02:02:41 PM »
i cant think of how close it is to the rear panel on the bis, i suppose if push came to shove you could manage it in situ however to make it a damn sight easier i would remove the rear panel anyway.
jdobson
« Reply #2 on: August 17, 2012, 04:59:10 PM »
Hello. Thankyou for yor reply, I will do that. Cheers. JOHN
« Reply #3 on: August 17, 2012, 05:04:07 PM »
Just make sure the engine is well supported, can't see it being easy with the back panel in situ.
Marc
« Last Edit: August 17, 2012, 05:17:38 PM by Hazey-n-Marc »
« Reply #4 on: August 17, 2012, 07:45:27 PM »
it would not be easy by any means but it depends on how lazy you feel...
« Reply #5 on: August 17, 2012, 07:59:25 PM »
Yes rear panel has to come off, support engine, remove alternator belt and unscrew!
