Author Topic: compression test  (Read 2531 times)
aircobra
compression test
« on: July 30, 2012, 12:12:30 PM »
hi all,
the mechanic has tested the comp and has given me 75/85. i noticed some people in the forum are claiming 120.
is it time for new rings and a valve grind? doesn't seem to use any oil and doesn't smoke
the mechanic was saying that maybe the valve clearance needs adjusting
DEYAN IYI
Re: compression test
« Reply #1 on: July 30, 2012, 01:46:26 PM »
Some time ago found this info in a Polish source:
600/650/650Е/ЕL/ELX...
Normal:
0,8 +/-0,05 MPa
8,15 +/-0,5 kg/cm2
8 +/-0,5 bar
Minimum:
0,65 MPa
6,65 kg/cm2
6,5 bar
126 BIS
Normal:
0,95 МРа
9,7 kg/cm2
9,5 bar
Minimum:
0,7 МРа
7,15 kg/cm2
7 bar
Cinquecento 700
Normal:
1,1 МРа
11,2 kg/cm2
11 bar
Minimum:
0,95 МРа
9,7 kg/cm2
9,5 bar
The difference between two cylinders must be maximum 0,1 МРа or 1 kg/cm2.
Better make a test with a leak down gauge and statoscope.
http://www.aa1car.com/library/leakdown.htm
Converted 1bar = 14.5038 psi
Then for the air cooled normal is about 123 to 109 psi and minimum 94,3 psi. :$
« Last Edit: July 30, 2012, 02:42:50 PM by DEYAN IYI »
