Author Topic: Gear Oil Change  (Read 2252 times)
RicePuddin
  • Guest
Gear Oil Change
« on: July 28, 2012, 11:38:02 AM »
With the nice weather I decided to change the gear oil. No big issues. The sump plug and the filler plug both came out with no hassles. My problem was that I had to buy two 1 litre bottles just to fill it with 1 litre. The starter motor was in the way. I just squeezed the top half of each bottle from below. Is there a handier way to fill it?
Re: Gear Oil Change
« Reply #1 on: July 28, 2012, 01:35:11 PM »
I think that Stuey posted a picture of a simple oil filler pump a few months back on one of the gearbox oil threads  :)
Re: Gear Oil Change
« Reply #2 on: July 28, 2012, 02:53:35 PM »
Kipster
Re: Gear Oil Change
« Reply #3 on: July 28, 2012, 07:44:35 PM »
I used a large syringe 100ml, if you know a cattle or dairy farmer they will have used ones.
nrg19uk
Re: Gear Oil Change
« Reply #4 on: July 28, 2012, 09:02:17 PM »
Neil gargaro
RicePuddin
  • Guest
Re: Gear Oil Change
« Reply #5 on: July 28, 2012, 10:24:38 PM »
After seeing the picture I made a tool from a large syringe that i had and a bit of pipe. I'm going to double check it tomorrow if the weather is ok.
Does anyone know the capacity. I filled it till it started coming out but when I drained it originally there seemed to be more than I could put in.
Re: Gear Oil Change
« Reply #6 on: July 29, 2012, 08:57:14 AM »
I think it's a total of 1.1L of oil but make sure the car is level when filling. I used a hose with a  funnel  and filled it in from above through the engine bay without a problem...
Sciu
    • Fiat 126 fanclub Lithuania
Re: Gear Oil Change
« Reply #7 on: July 31, 2012, 12:12:36 AM »
As I changed it I filled abuot 1,3L
RicePuddin
  • Guest
Re: Gear Oil Change
« Reply #8 on: July 31, 2012, 04:26:02 PM »
I got about 1.3L into mine too. Mine is a BIS. That may make a difference?? I used Castrol 80w-90.
I was talking to Stewart Walsh (Fiat specialist) and he said that 80w-90 is good but the best stuff is 90 but is hard to get and he can't remember who makes it.
