Author Topic: Clutch cable adjuster Nut?  (Read 1441 times)
mckenzie1970
« on: June 30, 2012, 06:13:08 PM »
Hi Guys, anyone know where i can get a nut to screw onto the clitch cable under car as theres only one oone and it keeps unwinding itself so clutch begins to slip. Had a look on ebay but cant see the correct one. Maybe i has the wrong nut on?
Any advice welcome
Many thanks
Re: Clutch cable adjuster Nut?
« Reply #1 on: June 30, 2012, 06:32:18 PM »
You should have two nuts on there, a special nut ,17mm A/F, which is like a dome nut but drilled & threaded right through. The dome bit locates in the clutch actuating arm then there shoud be an M6 lock nut. As I have found out in the past if that nut is not locked properly the cable will just vibrate loose.
mckenzie1970
« Reply #2 on: July 01, 2012, 12:18:42 AM »
Hi Rustys uncle.
I think youve described exactly the problem. There is certainly only one nut on there.
I wonder, is there anywhere that i can buy the nut required?.
Thank you for your reply
Kind Regards
« Reply #3 on: July 01, 2012, 09:45:32 AM »
mckenzie1970
« Reply #4 on: July 03, 2012, 11:48:59 PM »
thanks chris, i can see that its the small nut that is missing on your diagram.
I am presuming that the part number and i can get one from fiat.
Many thanks guys
« Reply #5 on: July 03, 2012, 11:54:35 PM »
If it is the small nut - Part No 15896211 missing, you should have no problem getting one from a motor factor it's just a standard metric nut.
