Author Topic: Sound deadening  (Read 3291 times)
Sound deadening
« on: June 15, 2012, 05:29:57 PM »
If I installed some of this or something similar over the engine compartment in my BIS do you think it will cut engine noise?
http://www.ebay.co.uk/itm/Car-Sound-Proofing-Acoustic-Jute-Felt-Soundproofing-25-00-2-meter-x-1-37-wide-/220980638965?pt=UK_Car_Interior_Accessories&hash=item337378f4f5
Has anyone tried sound deadening in there 126 and does it work?
Re: Sound deadening
« Reply #2 on: June 15, 2012, 05:46:23 PM »
You could probably get some idea using old blankets over the engine lid. Under the rear seat and the floor should help, the roof makes a lot of difference if that isn't sound proofed.
Re: Sound deadening
« Reply #3 on: June 16, 2012, 06:45:51 AM »
I have been thinking about sound deadening or noise reduction materials for ages but can't decide which ones to go for. I have installed Dynamat on the roof of my Bis i.e. prior to installing my DIY headlining. It works a treat. I intend to install a similar material to the floors and particularly the engine compartment, are next in line. Did a bit of reading on this but not sure how these materials actually perform. For what is worth, here is my short list. Price was a major factor.
http://www.ebay.co.uk/itm/sound-proofing-heat-insulation-sheet-closed-cell-foam-size-2metre-x500mm-x-6mm-/300693367557?_trksid=p4340.m185&_trkparms=algo%3DDLSL%252BSIC.NPJS%26its%3DI%26itu%3DUCI%252BUA%26otn%3D10%26pmod%3D350498554210%252B350498554210%26po%3D%26ps%3D63%26clkid%3D9168371259261122538
http://www.ebay.co.uk/itm/car-FELT-sound-fire-proof-carpet-acoustic-matting-mat?item=300511408951&cmd=ViewItem&_trksid=p5197.m7&_trkparms=algo%3DLVI%26itu%3DUCI%26otn%3D3%26po%3DLVI%26ps%3D63%26clkid%3D9168294434797109678
http://www.ebay.co.uk/itm/300631444960?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
There were others too but were quite pricey, so they dropped of the list. The bought Dynamat in the past, it works, but it was too expensive.
« Last Edit: June 16, 2012, 06:14:27 PM by Amateb8 »
Re: Sound deadening
« Reply #4 on: June 16, 2012, 06:09:33 PM »
I have been thinking about sound deadening or noise reduction materials for ages but can't decide which ones to go for. I have installed Dynamat on the roof of my Bis i.e. prior to installing the headlining. It works a treat. I intend to install a similar material to the floors and particularly the engine compartment, are next in line. Did a bit of reading on this but not sure how these materials actually perform. For what is worth, here is my short list. Price was a major factor.
I don't have any headlining and would like to make one but I need a template, have you got one?
Re: Sound deadening
« Reply #5 on: June 16, 2012, 06:13:06 PM »
I still have my old headlining. I will do a template of it but what should I use?
This was my thread on the headlining.
http://club126uk.co.uk/smf/index.php?topic=5657.0
« Last Edit: June 16, 2012, 06:16:07 PM by Amateb8 »
Abiella
    • The Box Collective
Re: Sound deadening
« Reply #6 on: June 17, 2012, 03:01:29 AM »
I would like to do some sound proofing too... Let me know what you find best, I think I will try some Dynamat on the roof as its collapsing anyway... I have got pretty used to the noise but my friends seem to think its very loud.!
I drive on Button Moon...
Re: Sound deadening
« Reply #7 on: June 17, 2012, 07:14:08 AM »
Yes, it does make a huge difference! Here is another one on my short list for the floor and engine comparment but you can use this for the roof as well. If it is just for the roof, you will not need a lot. You will probably need just two pieces of the attached.
http://www.ebay.co.uk/itm/270600833127?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
« Last Edit: June 17, 2012, 10:44:33 AM by Amateb8 »
Re: Sound deadening
« Reply #8 on: June 17, 2012, 08:47:15 AM »
Could you make a template out of tailors paper, like grease proof paper and post?  May be draw a pic of it and put measurements on and post a pic?
Re: Sound deadening
« Reply #9 on: October 04, 2012, 08:16:14 PM »
Sorry, I have not forgotten. I did a template on my spare felt (grey) material, the same one that I used in my Bis. I had a senior moment - I inadvertently threw the original headlining. I realised afterwards, that I no longer have a template apart from what I did for you. I will do another template for myself and will send you the spare one.
Re: Sound deadening
« Reply #10 on: October 07, 2012, 09:13:16 PM »
Cheers mate :D
Kent126
    • Facebook Profile
Re: Sound deadening
« Reply #11 on: October 28, 2012, 06:48:11 PM »
Good idea, although I am not sure if I would want to deaden the sound in mine. Sort of spoils the 70's driving experiance! lol ;D
1974 Italian Fiat 126 TA
2008 Fiat Panda 100HP
guy2yourleft
Re: Sound deadening
« Reply #12 on: November 02, 2012, 05:29:01 PM »
I have Dynamat installed in my 94 Explorer and 67 Mustang and the inside is nice and quiet aside from what the windows let in. It isn't the cheapest sound-deadening stuff out there, but I would recommend it to anyone. I plan on installing a lot of it in my 126.
I didn't do it!  ...unless it was good...  ...even then it's still debatable...
Proud parent of a '67 Ford Mustang, '83 Fiat 126, and '94 Ford Explorer: "Daddy's Lil Girls"
Re: Sound deadening
« Reply #13 on: November 02, 2012, 07:08:00 PM »
On my 126 Bis, I ended up using the Dynamat Superlite Pack after buying the Dynamat Extreme. The Dynamat sound deadening material does the job quite well, but the material feels quite heavy. I would recommend Dynamat to anyone, but for the 126, suggest the superlite version.
