Author Topic: Oxygen  (Read 3444 times)
Oxygen
« on: June 12, 2012, 06:40:02 PM »
Does anyone know where I can get a Oxygen bottle refilled (Beergas) :headscratch:
Or know a friendly landlord that might swap an empty bottle for a full one (paid of course). :secret:
Not too far from Essex would be a huge plus.
I have a Mig, it came with a 'empty bottle'. I know I can buy the Halfords disposable ones, but would need to change over the connectors, and I already have valve and Gauges.
Any ideas, last time I welded was about 1980   :o  so a bit out of practice. Really don't want to invest too much as want to have a go before blowing holes in my 126's floor. :-
Re: Oxygen
« Reply #1 on: June 12, 2012, 06:50:32 PM »
Are you sure that you have got the right gas there mate ?
Re: Oxygen
« Reply #2 on: June 12, 2012, 06:53:29 PM »
I know that Argon/oxy mix is better but for the little bit I will be doing just the (beergas) Oxygen should be good enough, so I am told.
I must admit when I welded (a while ago) it was gas welding and arc welding though.
nrg19uk
Re: Oxygen
« Reply #3 on: June 12, 2012, 07:41:33 PM »
Should be Co2 not oxygen ;-) no need for argon if you have a nice flow.
Those little halfords bottle only last a max of 15 mins if you have the right flow.
Neil gargaro
Re: Oxygen
« Reply #4 on: June 12, 2012, 07:48:35 PM »
 :$  CO2  :$  :shy:
Re: Oxygen
« Reply #5 on: June 12, 2012, 08:07:56 PM »
I'm never borrowing your diving equipment  :o
Re: Oxygen
« Reply #6 on: June 12, 2012, 08:13:10 PM »
:P
Re: Oxygen
« Reply #7 on: June 12, 2012, 08:46:51 PM »
Go for nitrous oxide , your welding will be crap but with the flow turned up you will have a lot of fun trying  ;D
smallcox
Re: Oxygen
« Reply #8 on: June 12, 2012, 09:18:56 PM »
Don't you just love it when everyone takes the biscuit :)
The pub gas is the stuff used to put the bubbles in your bath-sorry pepsi. This is what I used and it works well even on stainless steel. However finding some is hard. I had to purchase a bottle and then have it filled at a gas welding supplier at from what I remember cost me £40 or there about. ???
Re: Oxygen
« Reply #9 on: June 12, 2012, 10:00:17 PM »
I have the bottle just need to find a 'friendly'  ;) place that will fill it for me.
RicePuddin
  • Guest
Re: Oxygen
« Reply #10 on: June 13, 2012, 04:36:10 PM »
Doesn't the gas depend on the type of welding? MIG is commonly CO2 and oxy-acetylene uses Oxygen and acetylene.
My mate once used a CO2 fire extinguisher as he had run out of gas. It worked too.
Re: Oxygen
« Reply #11 on: June 13, 2012, 07:08:09 PM »
That Irish / gas connection sparks a memory  :o
I was visiting a mate in Westport , Co. Mayo and having a glass or two in John McGinn's bar. A man came in the bar appealing for help as his car had broken down outside. My pal Malc who is the most "naturaly born" mechanic I have ever known diagnosed a blocked carb and it needed a high pressure airline to blow it through. A little bit of head scratching then John McGinn came out with the Co2 bottle that he had disconnected from the Guiness pump  ;D
A quick blow through, mate covered in petrol, then the guy was on his way  :)
Guiness back on line so life went on !
Re: Oxygen
« Reply #12 on: June 13, 2012, 07:22:20 PM »
Sometimes fire extinguisher refill companies will refill the pub type bottles, used to do it regular a few years ago.
Re: Oxygen
« Reply #13 on: June 13, 2012, 09:24:24 PM »
try these people
www.adamsgas.co.uk  they do non deposit gas.
Re: Oxygen
« Reply #14 on: June 13, 2012, 09:32:58 PM »
these are the nearest stockists in your area    senator welding & Engineering Supplies
        Unit 20 Hedley Avenue
        West Thurrock
        Essex, RM20 4EL
        0845 5197639
i would go for argon/co2 mix as it gives a cleaner weld and just a word of warning if you are using galzanized steel as a repair patch it gives off a poisonous gas!!
