Author Topic: question to those that know....  (Read 5543 times)
gsxr126
Re: question to those that know....
« Reply #15 on: May 16, 2012, 12:27:55 AM »
from what i know, these things were designed to give best effect at max revs/full throttle, so I would agree with Pete in getting a good standard tune on your carby. I know a bloke that re-routed all the cooling ducts on an aircooled to the carby and he claims he's getting 3.5 pounds boost  ;D so it might give some benefit.
btw, good job on getting that car running after your truck incident, that thing was rooted.
« Reply #16 on: May 16, 2012, 03:34:24 PM »
i went out and installed the "turdo booster" thing on my car today and just standing next to it could feel the extra power that it is making i shall post some pics later after i have recovered from my exertions, in order to fit it i had to modify the elbow on top of the carb as it sits too high, make a new accelerator/ carb linkage rod as the standard is too short and generally fettle the actual shape of the base as the fit is quite poor considering it has been designed for this car!  the actual unit ideally needs to be around 6mm shorter as it leaves no clearance between the filter neck/elbow and the engine bay roof!
« Reply #17 on: May 16, 2012, 09:32:49 PM »
feel the power!! ha ha ha ...
nrg19uk
« Reply #18 on: May 17, 2012, 06:52:37 AM »
Video clip???  :D
Neil gargaro
« Reply #19 on: May 17, 2012, 06:59:19 AM »
 Mick you should have just cut a hole above the carb, stuck the air filter in there, than it would have been properly supercharged and with your new turbo gadget, you could have given Smallcox run for his money :P
« Reply #20 on: May 17, 2012, 08:23:06 AM »
or just get a small child to blow into it as they pedal!
Tate
« Reply #21 on: May 17, 2012, 08:41:34 AM »
I'm speechless  :D
Fiat 126 -73 project
2 x BMW E21
« Reply #22 on: May 19, 2012, 02:44:32 PM »
well i now know that this is a waste of time as i have played around with this device and have been down on power regardless how i try to set it! i have removed it and my car is back to normal....i shall now make it into an ashtray.........
« Reply #23 on: May 19, 2012, 06:42:26 PM »
E bay. Rare Turbo for Fiat 126. 100 pound it will go in seconds  ;D
popik81
« Reply #24 on: May 19, 2012, 10:36:44 PM »
I cat fid it... lik please
nrg19uk
« Reply #25 on: May 19, 2012, 11:49:24 PM »
Here's some n's nnn lol
Neil gargaro
