Author Topic: 750 engine  (Read 2653 times)
amam
750 engine
« on: May 10, 2012, 10:07:35 PM »
hi, just a quick question but found this on the net
http://webshop.fiat500126.com/index.php/katalog/artikelinfo/6389-1-set_of_cylinder_liners_750_cc_82_mm_with_pistons_and_rings.html
its a Set of cylinder liners 750 cc (82 mm), with pistons and rings, just wondering if anyone on forum fitted these ect what it entails?
Re: 750 engine
« Reply #1 on: May 10, 2012, 10:15:24 PM »
 Check out this site, they have a good selection and slightly cheaper.
 http://www.fiat500sport.com/engine-assembly.html
 I think you need to get the engine block opened up for that set up.
ypsilon_lancar
Re: 750 engine
« Reply #2 on: May 10, 2012, 11:50:36 PM »
Wouldnt the vw 1600 conversion be cheaper?
popik81
Re: 750 engine
« Reply #3 on: May 11, 2012, 12:16:06 AM »
1600?? where put it in?? on back seats??
Re: 750 engine
« Reply #4 on: May 11, 2012, 01:22:52 PM »
A lot cheaper but more work to fit £154 for a set of 4 barrels, pistons, rings and gudgeon pins and retainers.  Split between two only £80 ish.  Sounds OK to me.
http://www.vwheritage.com/vw_spares_Barrel-piston-kit-1600cc-Mahle-Cast-piston-or-use-KS_act_shop.product_pID_123823_lang_EN_country_GB.htm?crumbPageToLoad=1?crumbStartRow=1
Re: 750 engine
« Reply #5 on: May 11, 2012, 01:46:05 PM »
Just checked costs the FIAT option for 800cc is £580 ish and the dia is 80mm.  The vw alternative is £80 ish and the dia is 85.5mm. I would asume from this the stroke must be almost equal.
amam
Re: 750 engine
« Reply #6 on: May 11, 2012, 03:01:56 PM »
so to make the standard fiat 650 into a 750/800 it would cost 580 in proper fiat parts plus reboring, rest just own rebuild work  :D
but for £80 using vw engine parts for nearly same outcome but how much modification would it take?
still no one has come forward to say they've bought any of these fiat parts to upgrade there engine
Re: 750 engine
« Reply #7 on: May 11, 2012, 06:20:31 PM »
The kit from Nanni Ricambi is for new cylinders, pistons etc as for the vw conversion so the price comparison is OK.  You will need to ask on the forum if anyone has carried out this conversion or I think there is a link to a POlish site where you can get all the information to do the conversion, in Polish.
ypsilon_lancar
Re: 750 engine
« Reply #8 on: May 11, 2012, 07:49:41 PM »
I think its 126fan that have the instructions and photos. it looks quite straight forward from what i read
amam
Re: 750 engine
« Reply #9 on: May 14, 2012, 05:29:49 PM »
so no one on here who has upgraded there engine to 750/800?
Re: 750 engine
« Reply #10 on: May 14, 2012, 06:57:49 PM »
I knew 2 people that had done the mod both engines lasted one hillclimb.
Re: 750 engine
« Reply #11 on: May 14, 2012, 07:09:48 PM »
I have a 795ccs engine but I did not build it as it was done by a specialist company in the mid eighties. I got it part dismantled and much to the annoyance of a couple of guys here I have not rushed into putting it into use but I have been making and preparing parts over the last couple of years and hope to do a full rebuild this year although I seem to spend all of my time just trying to sort out everyday running problems & a few gremlins. There are no identifying marks on the barrels or pistons but I assume they are VW 1600. I am going tro make every effort to get a positive ID on them before I assemble the engine. All of the VW 1600 barrels I have seen on eBay or elsewhere seem to have an upstand at the top of the barrel which of course would not fit even after the crankcase had been bored out so I am on the lookout for a vw expert  :o
I was told by the guy who owned the engine that it had done 3 to 4,000 miles , it put out up to 56bhp and he had to put bags of sand in the front to hold the front wheels down  :)
