The tyre walls will be taller. This will decrease the fuel consumption as much as being wider will increase it.
Tyres are part of the suspension, the walls of the tyre move, so the taller the tyre the better the suspension in the tyre giving less movement in the rest of the suspension meaning less wear.
I have that size on the back of the BIS, they are absolutely fine, no rubbing.
Don't forget they will change the gearing, making your speedo read slower than you are going (by a small amount)
