Author Topic: Outdoor car cover for 126  (Read 1492 times)
fei
« on: May 09, 2012, 01:38:59 PM »
I'm going to pick up my first 126 today but will have to park it on drive way until i find a garage
where can i find a suitable out door cover?(cheap)
or anyone have a spare one?
cheers
Re: Outdoor car cover for 126
« Reply #1 on: May 09, 2012, 10:08:00 PM »
I think Bar Vitelli sell them.
Bar Vitelli
« Reply #2 on: May 09, 2012, 10:31:38 PM »
Mine were nice but a bit too pricey (imported from Italy), depends what you are after, you can get relatively cheap off of eBay, or pay top cash (but it's worth it if you don't have a garage) for a Carcoon...
Every cloud has one...
fei
« Reply #3 on: May 09, 2012, 11:16:36 PM »
Thanks I'll have a look at the carroon, are universal "small" car covers too big for the 126?
Just wondering say if u drive home rainning, does it make it worst to cover it straight away? So the water traps inside I mean??
« Reply #4 on: June 23, 2012, 12:11:58 PM »
I think it would i.e. if covered straightaway. There are a couple of threads re car covers. In my opinion, think there are more upsides than downsides to using one.
« Last Edit: June 23, 2012, 12:35:56 PM by Amateb8 »
« Reply #5 on: June 23, 2012, 01:31:16 PM »
i would never cover a wet car as it would only trap the moisture between the car and cover and not be of any purpose however if you dry the car off or wait till it is dry then obviously it will be beneficial in the long run and will provide protection to the car, the important thing is to not get any moisture underneath the cover so you must be cautious that the cover does not condensate in hot weather.
« Reply #6 on: June 23, 2012, 08:01:24 PM »
I agree 100% with bis13.
Now that you mentioned the hot weather. I usually wait for the engine to cool down a bit, before putting the cover on. I find that if you put the car cover on whilst the engine is hot, the warm air coming out the rear engine air vents on either side of the car, mixed in with the air trapped underneath the cover, cause condensation. Furthermore, I think the engine cover does not completely keep the engine heat out. I was quite astonished to see lots of condensation on the outside rear windscreen and a wideish area of the rear wiper area. The condensation was literally trickling down! It is best to make sure the engine cools down in hot or cold weather (probably more so in cold weather) before putting the car cover. So be aware!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
