Author Topic: Rear window drain holes - why ?  (Read 1386 times)
GTodd
« on: April 23, 2012, 08:30:11 AM »
Hi. My recently acquired 1981 Personal 4 650 has two drain holes beneath the rear window. Mine are just bare holes, you can see daylight from the inside. A workshop manual shows a complicated two piece drain thing for each side. Are these holes critical, I'd like to just plug them with some kind of grommet. The car's a beaut. I'm reverting from the Polish plastic bumper and side stripe look, to the early series chrome bumpers. Thanks from New Zealand.  Todd
nrg19uk
Re: Rear window drain holes - why ?
« Reply #1 on: April 23, 2012, 10:17:07 AM »
They allow the water out that builds up, the window seals are not a water tight seal.
I used a silicon sealant to seal mine into place there gonna be a pig to remove if I need to.
but I have leak free windows
Neil gargaro
DEYAN IYI
« Reply #2 on: April 23, 2012, 11:21:54 AM »
You can see many pictures of rotten metal beneath the rubber, both front and rear window. Only because of plugged drain holes (naturally plugged).
When I was painting mine, welded nice metal pipes with outer diameter about more or less 10mm (the first pipe that I saw looking proper). On the rear one from wall to wall (the square profile between the window and the bonnet), on the front one just the upper ending, on the other is a plastic hose to lead the water to the side blinker.
When putting back together, clean the gasket nicely in warm water. It becomes soft almost like a new one :)
« Reply #3 on: April 23, 2012, 04:01:38 PM »
This is the part:-
This is what happens if they get blocked  ;D
« Reply #4 on: April 23, 2012, 07:32:44 PM »
Hi Todd , welcome and good to see you on the forum. You can always blame any problems that you have with the car on the previous owner  ;D  I had a good chat with him last week on the phone but as yet we have not met up. It was a case of weather forcast halted road trip and I am now back in the UK. I will have to catch up with you guys on the next trip  :)
