Author Topic: Hole at end of sill!  (Read 1406 times)
« on: April 14, 2012, 06:28:26 PM »
I have found a small hole at the end of the sill at the rear off side as indicated in the pic below by the red dot:
I have cleaned it up and it is just the right size too stick in the waxoyl spray gun to fill the sill.  So I don't really want to permanently fill it in because it gives me access.
What can I temp fill it with?
Re: Hole at end of sill!
« Reply #1 on: April 14, 2012, 07:31:44 PM »
 :headscratch: Psst' Ciao, that's the front near side ;)
Marc
« Reply #2 on: April 14, 2012, 07:33:19 PM »
Depends if the mot bods approve really, If they do a rubber grommet would probably suffice as long as the surrounding metal work is solid.
Marc
« Reply #3 on: April 14, 2012, 08:02:55 PM »
Marc
Opps!  Yes the other end, just testing! :$
Yes rest of metal is fine so I think I will stick in a rubber grommet as you suggest.
