Author Topic: Fiat 126 ELX with catalytic converter easier for MOT?  (Read 7548 times)
fei
« on: April 07, 2012, 04:33:13 PM »
Hi everyone I am a new 126 admirer  :D
Been reading some posts regarding getting those £300 Polish bangers registered in the UK....
Forum member saying post-92 models will not pass MOT because they need CAT
So how about "Fiat 126 ELX" arent they leave factory with catalytic converter?
If it passes MOT, got the Polish logbook from the seller, plus £55, and taxed it will be registered and road legal right? It doesn't sound too difficult, wondering why don;t the seller do it if its easy?
Re: Fiat 126 ELX with catalytic converter easier for MOT?
« Reply #1 on: April 07, 2012, 04:43:26 PM »
 Most of the sellers don`t get them registered as they would need to get them insured and get them TAX-ed at least for 6 months and it`s also questionable if the car will pass a UK MOT straight away.
 You might be able to get away with an exhaust without a cat, depending on the MOT center.
 I don`t think the 126s ever had cats fitted from the factory.
« Reply #2 on: April 07, 2012, 05:32:04 PM »
I have still been unable to find the piece I originally read, the cat wasn't mentioned, it was a very late 126 (mid 90's), the problems were noise and emissions, I know the decibel levels aren't normally checked for a mot, believe it is part of the more stringent one off test for imports. It is probably why the export 126's stopped when they did but carried on for polish market.
Marc
Think they fall foul of this due to date of manufacture being before full EU compliance.
First registered outside of Europe? In this case the vehicle is unable to come via our scheme, without
a full, original, European Certificate of Conformity. Even if the vehicle has since been registered within
Europe, without a European Certificate of Conformity, we would not be able to accept the application.
In these cases you would need to contact VOSA to have your vehicle inspected under the Individual
Vehicle Approval scheme.
« Last Edit: April 07, 2012, 05:38:38 PM by Hazey-n-Marc »
« Reply #3 on: April 07, 2012, 05:39:45 PM »
The full import registration document.
http://www.direct.gov.uk/prod_consum_dg/groups/dg_digitalassets/@dg/@en/@motor/documents/digitalasset/dg_071776.pdf
If someone can figure out a way to 100 percent insure passing this test they will be able to devalue all of our cars, uh sorry  :$ , I mean make a bit of cash and bring loads more lovely 126's over.  :D
Marc
« Last Edit: April 07, 2012, 05:51:28 PM by Hazey-n-Marc »
« Reply #4 on: April 07, 2012, 06:01:48 PM »
Would it be possible to bring them over for a reshell of an earlier export model?
« Reply #5 on: April 07, 2012, 09:38:11 PM »
The consensus was that, the late 126p's were quite difficult to get Mot'd due to emmissions. However, interestingly, there was a 2000 model year 126p with UK registration with a UK MoT that recently sold on ebay. There is another 2000 126p with a UK MoT as well currently on sale in ebay.
  http://www.ebay.co.uk/itm/FIAT-126-p-2000-/170819014775?pt=Automobiles_UK&hash=item27c59b5077
fei
« Reply #6 on: April 08, 2012, 04:41:50 PM »
Just wondering is it just the first MOT that is make or break?
Or we will have the same problem every year when re-mot?
« Reply #7 on: April 08, 2012, 04:53:57 PM »
It is the IVA test that is the problem.
« Reply #8 on: April 08, 2012, 05:21:44 PM »
I thought there was a plastic box of charcoal that was used to filter the emissions from the newer cars  :)
« Reply #9 on: April 08, 2012, 05:23:21 PM »
And you could tie a duvet over the back to reduce the noise :D
I think there is a test for decibel levels inside the car as well as outside. External is 84 db.
« Last Edit: April 08, 2012, 05:25:36 PM by Hazey-n-Marc »
« Reply #10 on: April 08, 2012, 05:43:40 PM »
http://www.businesslink.gov.uk/Transport_files/IVA_Information_Guide.pdf
Page 30 lists the relevant tests
Bit more info
http://www.dft.gov.uk/vosa/repository/SVA%20to%20IVA%20Guide%20v1%20April%2011.pdf
£199 for the test.
Believe they stopped being sold in the UK due to being unable to comply when the stricter tests came in, therefore they were never approved under the eu compliance directive meaning they have to undergo this test. There are ways around it, but you would have to be resident of the country the car was being imported from and have owned the car there for 6 months.
« Last Edit: April 08, 2012, 05:57:30 PM by Hazey-n-Marc »
« Reply #11 on: April 08, 2012, 05:52:40 PM »
 It only needs a standard MOT, and as I said it depends on the MOT center how strict they are. There is plenty of post 92 126s registered in the UK.
 Just think of how many modern cars have they cats removed. How they go through an MOT every year?
« Reply #12 on: April 08, 2012, 06:00:06 PM »
Only 16 post 92 according to howmanyleft.co.uk, and half of them are sorned.
Sorry 19, I miscounted :$, four of these are 93-94, so could just be 92 cars that did not sell. The site doesn't give build date, so they could be pre 92 cars, I agree with you that there are some post 92 cars though.
I have posted all of the legislation I could find, I have read most of it. Please do the same if you are interested, because I don't plan to re read it anytime soon. (story line was frankly pooe  :D)
« Last Edit: April 08, 2012, 06:06:31 PM by Hazey-n-Marc »
« Reply #13 on: April 08, 2012, 06:02:57 PM »
 But it proves it`s possible. One of them on sorn is mine. Looking rather sad at the moment :$
« Reply #14 on: April 08, 2012, 06:08:52 PM »
Did you bring over yourself? How much hassle and when? They have been updating these laws for years, the biggest changes look like they were in 2007.
I am just reciting legislation, so I really have nothing to loose from being proved wrong, I was just interested in how feasible it would be when fei asked.
I think this is an important issue, Can you use a second hand shell to reshell an older car for instance. If you can, it would be worth bringing them over to save the basket cases.
« Last Edit: April 08, 2012, 06:32:00 PM by Hazey-n-Marc »
