Popik81 that last link you put on there had the part i need near the bottom of the page ,
Man are things cheaper in poland !
Hazey-n-marc i did get the housing , from a member on here .
I have got a spare engine for my bis which has 15,000 miles on it, ( mine has 45k)which i am kinda going to town on. I plan to replace the front and rear oil seals as the timing cover end one is leaking. The engine had a broken thermostat housing from where it had been removed from a mint 126 which believe it or not had been put in on the scrappage sceme a while back .
So i want to replace with new parts , i took the old seal out after removing the rusty impeller .
My plan is to paint the block red and polish all other bolt on parts
Then swap engines
Parts seem to be a lot more available in poland , bleedin england
