Author Topic: will fit??  (Read 1758 times)
Re: will fit??
« Reply #1 on: February 28, 2012, 12:26:48 PM »
Not a direct fit  :D Would need modification...
popik81
Re: will fit??
« Reply #2 on: February 28, 2012, 04:50:18 PM »
what have to be done?? temp of oil and rpm for sure... what more??
Re: will fit??
« Reply #3 on: February 28, 2012, 07:03:47 PM »
The speedo cable is a push fit on the Cinquecento, on the 126 it screws in you also have to make brackets to mount the dials into the 126 pod, as far as i can work out the warning lights should work when you connect the 3 dashboard plugs, The tacho would need some electronics to make it work ;D
DEYAN IYI
Re: will fit??
« Reply #4 on: February 28, 2012, 07:13:58 PM »
Probably the speedometer has different ratio, and if you think that 140km/h is pretty enough :$, you can use the original EL/ELX model (the last one y. 1994-2000). Otherwise it won't show the correct speed. Have no idea if there is mph or mixed as well. The speedo cable of this one is a push fit too.
RPM to be turned to 2 cyl. (If there is no potentiometer, as Pete says, it will need something more).
It's pity that the factory haven't do it at least for the "Happy end" model ::) Looks like real car 8) And there is no the hateful tire pressure drawing.
popik81
Re: will fit??
« Reply #5 on: February 28, 2012, 11:30:39 PM »
first I check howit looks like in "happy end" and then will think... (im not good electronic  >:( )
it was same like in "town" ??
"And there is no the hateful tire pressure drawing. " well for me worst is that from petrol(swings like a boat)
« Last Edit: February 28, 2012, 11:49:13 PM by popik81 »
