Author Topic: Calculating offset of steel rims  (Read 2217 times)
« on: February 13, 2012, 10:30:15 PM »
Hoping someone can tell me where I am going wrong, or confirm if am measuring this right.
I have been trying to calculate the offset of a late 126 aircooled rim
  • I've measured a 126 rim width at 170mm. (This is the gross width and not the 'J' value stamped on the rim.)
  • dividing this by 2 gives a centrline of 85mm
  • backspace (inboard mounting face to inboard rim) = 140
  • offset = backspace - centreline
  • = 140 - 85 = 55mm
Using the same method I worked out the offset of a mk1 punto rim to be 68.5mm
I've found a few lists online that supply this data and while none of them can be verified, they all claim a punto should be between 30-40mm which makes a bit more sense to me.
Can anyone shed any light?
Re: Calculating offset of steel rims
« Reply #2 on: February 14, 2012, 01:32:18 PM »
http://en.wikipedia.org/wiki/Offset_(wheel)
Thanks Meelisv.
Thats the first article I looked at and most others seem to concur with the method.
the calculation is quite simple, but the result doesn't match my expectations! has anyone else calculated the offest and come up with a different result?
Allan
« Reply #3 on: February 14, 2012, 07:28:27 PM »
As I see it the ideal situation is to have the centre line of the wheel as close to the centre line of the wheel bearings as possible so as not to load one or other of the bearings excesivley. This means that front wheel drive cars have more offset (or ET which is an abreviation for a German word I can never remember) than rear wheel drive. The wider the wheel you fit the greater the ET should be until you reach a point at which the wheel fouls some part of the suspension. In general the greater the ET the further in towards the centre of the car. It is possible to use spacers to get the ET correct. On our Toyota ST165 GT4 we had to fit 12mm spacers to allow us to use the wheels from the later 185 and 205 versions because these had an ET of 35mm. We at one stage thought of using Subaru wheels but these have a 45mm ET. A lot of it has to do with the way brakes and flanges are set up by the manufacturer. Fiat seem to have very little difference between front and rear wheel drive offsets (ET) somewhere around 10 to 15mm. We use Lancia HPE wheels on our 124 Special T with only sufficient spacers (6mm) to prevent fouling.
Allan
« Reply #4 on: February 14, 2012, 07:35:34 PM »
Just to throw a little more in there, remember that offset (ET) is a measurement from the centre line of the wheel to the mounting flange. Also remember that the size stamped on a wheel is the size of the mounting point of the tyre and that the overall width is one inch wider.
« Reply #5 on: February 14, 2012, 08:08:55 PM »
Thanks Allan,
I hadn't considered this aspect before and it makes a fair bit of sense to me so I may as well calculate the bearing centre and find out how it lines up with the wheel centre. The wheels I'm trying to fit are fouling the rear arms and before I get a set of spacers I wanted to find out if this would fix the problem, or just overload the bearing by shifting the weight to the other side!
I've still got no idea why my calculations do not seem to match those I've found on websites, so I'm still happy for someone to correct my calculations!
« Reply #6 on: February 14, 2012, 09:13:20 PM »
Have you not considered that the square on the hypotenuse is equal to the sum of the squares on the other two sides ?
Or when a body is totaly or partialy immersed in a fluid then the apparent loss in weight is directly proportional to your grip on reality  :P
« Reply #7 on: February 15, 2012, 09:38:29 AM »
Haha you said  Flange  :D
