Author Topic: First drive out today !  (Read 1905 times)
the duke of 126
« on: January 31, 2012, 07:07:18 PM »
Well i taxed the old boy today ( luigi ) and went for my first blast , i did 34 miles in him , i do have a few points to mention .
Man it was cold here in essex 1.0 c , was the heater fitted in these for a joke ?  :o
It was great fun though , i cant wait for a bit of sunshine and the warmer months ,
I also seem to have a sticky carb , from what i could see , the throttle cable was working ok , but there is a part of the carb just underneath the throttle mechanism that was sticking open , is that the choke part ?
Other than that , what fun ! I took a wide left hander over a bridge a bit too quickly and i could feel the back end starting to slide out a bit , i was not even hard on the revs !!!
I run minilight alloys on mine and they handle fine , but i think the speedo may be overeading , i aim to check it later tonight when i take him back to his lockup , are they known to be optimistic ?
It seems so weird flying along at 50 mph and being inches from the pass door , i am 19 stone and six foot so i may look a bit funny in it but who cares ?
I have a aftermarket steering wheel which resembles a button ! .
Bar Vitelli
Re: First drive out today !
« Reply #1 on: January 31, 2012, 07:35:08 PM »
Duke...you just described everything that is great about our cars!
There's lots of stress in life but as soon as I'm in my Fiat it is instantly forgotten!
Every cloud has one...
« Reply #2 on: January 31, 2012, 07:38:58 PM »
Sounds like you had a good blast ;D you got to admit they are really good fun to drive :P
the duke of 126
« Reply #3 on: February 01, 2012, 08:04:54 AM »
Funny thing , when i went to take him back to his lockup tonight , i put the heater on cold instead of hot and it started pumping out hot air , like really hot ! Somehow my heater works in reverse ?,
I thought it only wise to find a large roundabout and try drifting him , after my earlier slide in the day !
He drifts nicely  :D
All in the name of safety !
« Last Edit: February 01, 2012, 08:06:33 AM by the duke of 126 »
« Reply #4 on: February 01, 2012, 10:56:33 AM »
I think the return spring on your second venturi is sticking, it is the sring at the bottom left of the side of the carb facing you, just plus gas it and work it back and forwards until it frees off.
Marc
eben80
    • AircooledVWSA
« Reply #5 on: February 01, 2012, 01:05:32 PM »
Do you have an AC?
My heater doesn't work that bad, assuming I have the valve on the transmission tunnel & the ones in the dash set correctly. Also all your hoses & seals must be properly fitting.... I have hot air coming from my handbrake : ;D
« Reply #6 on: February 01, 2012, 09:01:22 PM »
Isn't Luigi an orange 126 Bis watercooled? If it is, the heating system is very effective. Just move the top lever fully to the right for maximum heating. Lever 2 (middle) also fully to the right for maximum airflow. Lever 3 directs the airflow. I usually use the windscreen demister - the lowest lever fully to the left. Like all cars, you need the engine to warm up before it can emit hot/warm air. Enjoy!!
« Reply #7 on: February 01, 2012, 09:04:45 PM »
There are only two levers on mine! :o
Marc
