Author Topic: Headlights!  (Read 2086 times)
KatVonMe
Headlights!
« on: January 22, 2012, 07:42:59 PM »
How differant are the yugo or 127 headlights will they fit a 126? or simply modified to fit? anybody used a differant alternative? im struggling to find luigi a headlight! there as rare as like hens teeth!!
Re: Headlights!
« Reply #1 on: January 22, 2012, 08:28:59 PM »
I may have a spare, I will check the garage. Drop me a PM
Re: Headlights!
« Reply #2 on: January 22, 2012, 08:53:25 PM »
If David can't sort you out you can use these, just cover the R/H uplift triangle with chrome tape
Get a pair for 28 Euro (that's £23.25p) + postage
Re: Headlights!
« Reply #3 on: January 22, 2012, 09:15:37 PM »
Hi I have purchased hella rectangular h/lamp and audi frame, need to drill 3 holes in the existing back plate and fit. Hope to fit it soon when I get some spare time, will post photos.
KatVonMe
Re: Headlights!
« Reply #4 on: January 23, 2012, 09:34:15 AM »
pm'd dude! it might sound really fussy.. but i dont want 'beem bender' stickers on >_< they look terrible imo!
Da Londo
    • Fiat 126 blog
Re: Headlights!
« Reply #5 on: January 23, 2012, 06:40:43 PM »
The ones from 126fan can also be used for 127 and yugo so I think you can use them of the 127 or yugo.
Allan
Re: Headlights!
« Reply #6 on: January 23, 2012, 07:03:55 PM »
I have a pair of NOS right hand drive with H4 bulb fitting. Your problem is they are in New Zealand.
Allan
landyman
Re: Headlights!
« Reply #7 on: January 23, 2012, 09:49:44 PM »
i am sure someone posted a how to convert new l/h beam lamps to accept your r/h lens just involves sepparating the lens from the back using petrol or solvent and reataching with a pu adhesive only useful if the r/h lens is not smashed or cracked . anyone else know how to do this???
KatVonMe
Re: Headlights!
« Reply #8 on: January 24, 2012, 09:45:16 AM »
thanks everyone.. if i cnat find any would you be willing to price up posting them over to england?
KatVonMe
Re: Headlights!
« Reply #9 on: January 24, 2012, 09:46:48 AM »
thanks landy man.. but i dont have the lense hes had a smash to the front end with his preivious owner so all i have left is a cracked backing to the light.. :)
Re: Headlights!
« Reply #10 on: January 24, 2012, 10:11:28 AM »
The conversion to RHD lens was covered many times previously BUT the problem is always finding the relevant thread. I know this for a fact because I started a thread on this two years ago with a very good response. In a nutshell, as Landyman says, buy new or good condition used LHD headlamps. Remove the lenses and replace with RHD lenses. I think you just stick RHD lenses on the new reflectors with silicone or something similar. Other members will know the details. I shall try to look for the thread.
« Last Edit: January 24, 2012, 10:16:13 AM by Amateb8 »
landyman
Re: Headlights!
« Reply #11 on: January 25, 2012, 01:20:11 AM »
i can find r/h lenses to send you with u/s reflectors how many do you require ? just send for l/h lamps from one of our good suppliers like 126fan or ritz best adhesive is sikaflex [think thats how you spell it] try not to get it on your skin its strong stuff and clean everything before bonding together :good:
KatVonMe
Re: Headlights!
« Reply #12 on: January 25, 2012, 11:51:37 AM »
just the one (passenger side) :D ill get some money together then give you a shout :D i cnt wait to get luigi back on the road!
Re: Headlights!
« Reply #13 on: January 25, 2012, 12:18:31 PM »
I thought the lenses would be the same, however the pattern on the glass would be different (and the adjustment). I pulled apart a few headlights and the lense is smooth and shiny. It just reflects the beam towards the glass which then spreads it in the correct directions. There is a small cover on the bulb but I think that just helps direct the beam as well (for high and low beam but I can't remember exactly.)
Unless I'm mistaken and the correct name for the glass is a lense.... :$
