In Afrikaans we have a saying: "'n Boer maak 'n plan." Which means, "A farmer makes a plan when he has an unusual problem."
Some of you might now that I'm South African who lived in London for 7 years and now moved to Slovakia 6 months ago.
Everything is great. Except I'm still struggling a bit to communicate, especially with technical things.
Other thing, there are no(or I cant find them), tool shops or Halfords type places that you can go browse for what you want.
I've had the head off the 126 for a bit of a clean-up and to re-lap the valves. I removed the retainers by compressing the spring with a piece of tubing which worked. But of course I needed to get them back on again afterwards.
So... I had to make a plan. Went to the builders' warehouse and bought a cheap EUR7 clamp:
Used a HSS drill and some files to convert it into a valve spring compressor:
Took just enough off to make space to refit the retainers and took the sharp edges off:
Probably not as easy as a proper tool but I didn't have any issues and it didn't slip once(best to be careful though)
& Bob's your Uncle
Thought I'd share in case anyone else ever has the same situation.
