Author Topic: Timing Chain Tension (tensioner....)  (Read 1471 times)
fightingtorque
« on: January 11, 2012, 01:01:40 PM »
Got my old (spare, has some bits missing) engine on the bench looking at better ways of installing crank sensor.
I have taken the timing cover off and note that there is quite a bit of slack in the timing chain, I believe this is the main offender in terms of why these engines are rattly ( engine now in the car is also the same) so I will put a new chainset on anyway.
I was a little surprised that there is no kind of tensioning pad at all.  Minis that have a single chain have a product like this:
 http://www.minisport.com/mini-spare-parts/info_12G2621OE.html
I think it might be neat to add one to the slack side of the chain, if there is room.
Did anybody else ever try this?
Is there a spec for how much slack there should be/  what is it like when chain is new?
Gav
fightingtorque
Re: Timing Chain Tension (tensioner....)
« Reply #1 on: January 15, 2012, 10:15:55 PM »
I got one of the mini ones.  It is a bit too wide to fit under the cover.  I can thin it a bit, also I might get the relevant area of the crank main bearing retainer machined a little thinner (like it is where it clears the chain).
Can the retainer be removed without disturbing the actual bearing?
