Author Topic: bis thermostat  (Read 9183 times)
126redbomb
bis thermostat
« on: January 02, 2012, 11:22:41 PM »
Happy New Year to all.
I want to change the thermostat on my bis but I need to know if it only come as a complete unit or can I buy just thermostat. I think mine hasnt been changed for quite sometime and Im not to sure if its working properly ( it could have a blockage).  Does anyone know where to buy one from.
jokke
1980 Mazda RX626
1985 Mazda RX7
1998 Fiat 126p V6
126redbomb
Re: bis thermostat
« Reply #2 on: January 04, 2012, 04:14:24 PM »
Cheers for that.
 I think I need to test the thermostat and probably do a compression test.  I just hope the head gasket hasn't gone.
Re: bis thermostat
« Reply #3 on: January 04, 2012, 04:57:13 PM »
Most Bis owners remove the thermostat completely, the thermostat can cause problems due to poor design, that's what I have been told. ::)
Re: bis thermostat
« Reply #4 on: January 06, 2012, 04:37:19 PM »
Take it out before is sticks and ends up making tea  :P
Re: bis thermostat
« Reply #5 on: January 06, 2012, 05:44:27 PM »
I recently bought a thermostat and housing off of the internet for about twelve quid all in. needed a small bit of filing to make it fit as the shoulders holding the thermostat in place were a bit too proud, fine otherwise.
Marc
126redbomb
Re: bis thermostat
« Reply #6 on: January 06, 2012, 10:05:35 PM »
I've been looking everywhere on the net and 40+ quid is the best I can find, so £12 is WOW.  This might sound really thick but what do I need to do to plug the hole of the thermostat. :$ :D
Re: bis thermostat
« Reply #7 on: January 06, 2012, 10:21:52 PM »
Ebay, will try to find where, the box is still about somewhere. It is a complete unit, think you would have to
break the thermostat to remove it from the housing (not 100 percent on this).
Not sure why or which hole you want to block
Marc
« Last Edit: January 06, 2012, 10:26:55 PM by Hazey-n-Marc »
126redbomb
Re: bis thermostat
« Reply #8 on: January 07, 2012, 08:31:44 AM »
Sorry about the hole! It was late last night when I asked the question, after doing nights and having no sleep from the thursday my head was in a fog. ::)
 So I just have to pull the old thermo out of the housing?
Thanks for having a look for the box H n M, if you can get back to me that would be great.
Re: bis thermostat
« Reply #9 on: January 07, 2012, 08:42:30 AM »
There has been a lot of debate regarding to retain or remove the thermostat. I have kept mine. As long as the cooling system is regularly maintained, the current set up should be fine. If it takes a while for the engine to warm-up, then the thermostat needs looking at.
The thermostat allows the engine to warm-up quickly reaching its operating temp before allowing the coolant to flow through. By letting the engine warm up as quickly as possible, the thermostat reduces engine wear, deposits and emissions.
Re: bis thermostat
« Reply #10 on: January 07, 2012, 09:53:16 AM »
found the box, but only has minimal address on it, willtry to find out more.
Marc
Re: bis thermostat
« Reply #11 on: January 07, 2012, 11:16:07 AM »
Re: bis thermostat
« Reply #12 on: January 18, 2012, 12:51:34 PM »
On average a BIS does like 30000 miles before dying in a cloud of steam.
Get rid of the thermostat, you have been warned 8)
