Author Topic: Port Gasket Matching  (Read 1823 times)
eben80
    • AircooledVWSA
« on: January 02, 2012, 08:43:09 PM »
Evening guys. Has anyone done some exhaust manifold & head matching? The standard castings seem to have a lot of excess metal. The cast-iron elbows are surprisingly well matched to the gasket. I don't expect much but I suppose every little helps. Scribed the lines for the die-ginder.
Staying with the ports... should I be worried that the intake valve guides are protruding so far into the port? How would you normally cut them if you need to?
Re: Port Gasket Matching
« Reply #1 on: January 02, 2012, 08:53:21 PM »
it seems the the blitz boys have been removing all that protrudes how true this is i cant confirm.
fightingtorque
« Reply #2 on: January 02, 2012, 11:49:18 PM »
ideally you would remove the guides, get some new ones, turn them down in a lathe and then fit those.
It could be A significant improvement at higher valve lifts. Removing the guides may be a specialist job though, probably need to heat the head plus have a press.
The best reference I am aware of for the theory and practice of cylinder head modification is david vizard's book 'tuning your a series engine' although he does also have an earlier book called 'theory and practice of.....'
Even though it is about the a-series engine, it tells you what you would need to know to attack any kind of conventional tuning program, especially on a pushrod engine like the 126.
GAV
