Hi and happy new year!
Your motor is still alive
Do not kill him violently!
You said that the ignition is fine, but the effort to start and the sound later reminds me to mine when was trying to run with ... 20 degrees ignition delay
Anyway...
I noticed something to wary about
look the video after the 2min. The pump is making the fuel in bubbles, then when you twist the throttle
even worse - it turns to foam
Probably there is problem with the non-return valves. Check also the lift of the pushrod.
Here is something I've written before on this subject:
Try the non-return valves. When you suck through the inlet pipe, and blow through the outlet one (covering the pipe for the return fuel) shouldn't pass any air. If there is a leak, skim the contact surface on wet sandpaper (on something flat, table for example), but only turning, not sliding. On the picture to the left is done. If the "brown thing" is worn out (like the upper left one) just turn it round.
