Hi yes, its an aircooled. I'm a bit hesitant to do work on the crank as I'm not familiar with the process of measuring the journals, replacing bearing shells etc. then again I'll be replacing the sump gasket anyway so I might as well check for excessive play while down there.
126fan has the whole cylinder, rods, rings, pins & piston kits for EUR 186 but I will check the valves & rings first.
