I thought that would be the case , only because the bakelite block is bust,20mm thick but some are thinner probably for the 500 engine. Perhaps I could use the thinner block with a shorter rod but NOT cut down the longer rod of the 650 as I guess it hard faced ,a bit like sope shop assistances!!
